Thread: Econ light
Results 1 to 10 of 10
  1. Econ light
    Apr 2010
    London
    The Econ light on my A4 stays on, can't switch it off.
    I have checked the fuse and it's ok.
    i guess it's either a case of regassing, or faulty sensors.
    i should get my cable from Gendan this weekend so i can check to see if it's giving a fault code.
    anybody be able to recommend good independent to regas or change sensors in harrow or slough area?
    thanks
  2. Re: Econ light
    Southern County Softy
    20 Post(s)
    I've used these a few times for work on my A4 and the wife's TT
    http://www.theautopool.co.uk/
    A4 2.5 tdi QS (mapped)
  3. Re: Econ light
    Armitage, Rugeley, Staffordshire
    sorry to ask this but if the econ light is on is the air con "on" or "off"
  4. Re: Econ light
    Apr 2010
    London
    if the econ light is on, it means that the a/c is off.
  5. Re: Econ light
    cheers for that fella mine dosenot work either way round but will make sure its turned off now untill i get it fixed
  6. Re: Econ light
    Crawley
    are you guys talking about the button with the snow flake on it?
    '98 A4 1.8SE 235k miles..... and going
    '97 A4 1.8T 148k miles...... gone
  7. Re: Econ light
    Mine dosnt have a snow flake symbol, it says Econ on it if that helps.
  8. Re: Econ light
    Apr 2010
    London
    same with me. no snowflake, just says econ.
  9. Lightbulb Re: Econ light
    Crawley
    ok so in the lower left corner is the a/c button (the snowflake one)
    the reason i'm asking this is because this button enables the a/c for me.
    lets say i just started the car so everything is off (a/c, fans, everything)
    1. now if i press AUTO then the snowflake button automatically lights up and the a/c is on. after that if i press the snowflake button then i assume the a/c turns off because the light turns off.
    2. but if i press the + or - on the right side of the pannel (the ones under the fan level lcd) then the climate control starts on manual and the snowflake button does not light up.
    is it true that the a/c uses fuel? i mean if i set the temp level to 22 and there are only 20 inside the car then the climate control will blow hot air. so that means that the a/c does not have to be on so you can turn it off to save fuel.
    but if in summer time you set the temp level to a lower temp then the climate control will blow cold air and the a/c is on because the refrigeration system it is needed to cool the air so now it uses fuel. right?
  10. Re: Econ light
    Jul 2008
    stoke on trent
    the econ switch is facelift models
    so turning off snowflake is the equivilent i.e better economy if a/c is off
    you should still run it occasionally as it lubricates the system so hopefully it will work ok when you do need it
    99 a4 b5 1.8tqs saloon
    99 a4 b5 2.5tdi avant
    90 eunos roadster
  1. Question Fog lights install
    By deadly4u2nv in forum Golf MK5 - 2004 - 2009
    Last Post: 26-11-2014, 12:59 PM
  2. Brake Light Conundrum?
    By Eags in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 23-03-2010, 11:17 PM
  3. Foglights Retrofit - VW Jetta / Golf
    By RickT in forum Volkswagen
    Last Post: 27-06-2009, 06:06 PM
  4. Question should my car have brake pads wear indicator?
    By lucianus in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 04-05-2009, 12:19 PM
  5. A6 Econ Light
    By SKIPPY75 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 05-10-2007, 07:35 PM
