Thread: Passat B6 resetting service light
Results 1 to 10 of 10
  1. Passat B6 resetting service light
    May 2007
    Please can anyone tell me how to reset a B5 passat service light with
    VCDS software. I reset it the usual way thro the adaption 40-49 in the
    order it tells you but when you press the spanner on the dash its saying a service is due in 5000miles?
    Also im wanting to change the rear brake pads but wasnt sure if my software would wind the calipers back? Ive found this procedure and wondered if anybody knows if this works?
    Open Rear Parking Brake
    Procedure
    Cycle the Parking Brake ON, then OFF first.
    Select
    (53 Parking Brake)
    (Basic Settings)
    In Channel enter “007”
    Press (OK)
    The Brake callipers will then open, allowing the pads to be changed
    Press (OK)
    Press (BACK) to Exit from Module
    It is normal for the LED in the parking brake switch and the warning lamp in the instrument
    cluster to blink rapidly at this point.
    Close Rear Parking Brake
    Procedure
    Select
    (53 Parking Brake)
    (Basic Settings)
    In Channel enter “006”
    Press (OK)
    The brake callipers will then close
    Press (OK)
    The LED in the parking brake switch and the warning lamp in the instrument cluster will
    probably continue to blink rapidly. This should stop after cycling the Parking brake ON,
    Thanks in advance
  2. Re: Passat B6 resetting service light
    Canada
    What cable and software version are you using? I doubt the shareware version would do the calliper rewind function. if you have the newer version look here
    http://wiki.ross-tech.com/wiki/index...#Basic_Setting
  3. Re: Passat B6 resetting service light
    Norfolk
    To reset service on B6 use SRI reset on first screen. It gives you all the options. I haven't tried the rear pad change yet, so can't comment , but assume it works ok as no-one has said it doesn't.
  4. Re: Passat B6 resetting service light
    May 2007
    Its VCDS Release 908.2
    Data version 20100326
    Cable is a HEX+CAN
    Dual-k&CAn USB
  5. Re: Passat B6 resetting service light
    Sep 2009
    Apollo
    The SRI feature should work flawlessly when using the current VCDS release 908.2. It sounds like you changed the time and mileage values in the adaptation values 40-49. Please choose "General Service Reset" from the drop down menu.
    If you are looking to increase the mileage intervals please post the Auto-Scan.
    The 3C Passat brake procedure should work perfectly fine as long as you follow all of the instructions on the Wiki. The most important part is connecting a battery charger!
  6. Re: Passat B6 resetting service light
    May 2007
    Thanks for that, Why is it important to have a battery charger on?
  7. Re: Passat B6 resetting service light
    Canada
    Quote Originally Posted by gaz44 View Post
    High drain on the battery I would guess with engine not running.
  8. Re: Passat B6 resetting service light
    Norfolk
    If the voltage drops, the central electrics module will flag a fault. This can upset the brakes, esp, steering etc. A charger stops the voltage falling.
  9. Re: Passat B6 resetting service light
    Ambler, PA, USA
    In a few instances, we have had reports of the 53 module locking up and you cannot recover without replacing the module. VW and Audi both make the recommendation. I would advise you to adhere to their recommendation.
  10. Re: Passat B6 resetting service light
    May 2007
    Thank you to all, Ive reset service light ok and replaced rear brake pads no problem.
  1. Please Help Dashboard Cluster issues, rev counter, oil light and speedo
    By shaiboy_uk in forum Passat - B5 Forum - 1997 -2005
    Last Post: 28-12-2009, 11:31 AM
  2. Service light resetting?
    By Peterd213 in forum Golf MK4 - 1999 - 2004
    Last Post: 06-03-2008, 01:11 PM
  3. Service Interval.
    By shinglis in forum Audi A3 - Archive Topics
    Last Post: 08-11-2007, 01:55 PM
  4. Long Life service scedule interval
    By Ben in forum Chat - Anything with wheels
    Last Post: 27-10-2007, 04:48 PM
  5. service warning light
    By david1950 in forum Passat - Archive Topics
    Last Post: 29-07-2007, 10:33 PM
