Thread: How do I replace side light bulb?
  1. Question How do I replace side light bulb?
    Oct 2009
    Wiltshire England
    Hello people,
    My near side side light bulb in knackered so I bought a new one to replace it with, however I have noticed that the access to the bulb is tight.
    I removed the rubber cover from the back of the headlight however I'm not sure how to remove the bulb, I can kind of feel the bulb and where the wires go on to it but I don't want to force anything.
    How do I remove this bulb to allow me to replace it?
    I know this is a simple question however I just do not want to damage anything.
    Cheers,
    Dan
  2. Re: How do I replace side light bulb?
    daniel408 Guest
    With great difficulty. I have just changed both of mine and i found the near side one is a lot harder. I managed to get a pair of long nose pliers in there. Make sure you are happy that you have a grip on the bulb holder and not the wires, last thing you need will be that.
    They don't make it easy!!
  3. Re: How do I replace side light bulb?
    Oct 2009
    Wiltshire England
    Cheers for the reply, I'll have a look under the bonnet some time soon.
    Thanks,
    Dan
  4. Re: How do I replace side light bulb?
    jonda Guest
    i pulled the wires, eeek.
    i know i wasn't sposed to but... it worked.
  5. Re: How do I replace side light bulb?
    Jul 2008
    Norfolk, U.K.
    Having read this thread , am I right to assume that the holder simply "pulls" out and does not need to be turned ?
    I want to replace both of mine and obviously the last thing I want to do is break any of the wires
  6. Re: How do I replace side light bulb?
    Oct 2009
    Wiltshire England
    I still have not changed my bulb yet, I would also like to know is the side light bulb holder a pull out or is it a twist and pull job?
    Cheers,
    Dan
  1. Audi A4 Dashboard Instrument Panel Light Bulb Dash Light Fix
    By cbi004 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 17-07-2011, 08:39 AM
  2. Side light and indicator/hazard problem
    By Jock Doc in forum Passat - B5 Forum - 1997 -2005
    Last Post: 03-05-2010, 11:08 AM
  3. Side lights show on high level brake light?
    By joeb in forum Golf MK4 - 1999 - 2004
    Last Post: 21-06-2009, 10:15 PM
  4. brake light bulb!!!!
    By jjt5 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 30-05-2007, 11:09 PM
