Thread: TT S-Tronic vs A3 3.2 DSG?
Results 1 to 10 of 17
  1. TT S-Tronic vs A3 3.2 DSG?
    Feb 2010
    Hants
    Hi guys,
    Wonder if anyone can help on this. I sold my 56 plate 3.2 S-Tronic TT a couple of months ago (Broke my heart) in order to buy a house. Now the house is sorted I'm now able to free up some cash and buy something new.
    I can't afford to buy a new TT (yet!) but I was looking at an 04 plate 3.2 A3 DSG.
    I loved the S-Tronic on my TT, was 10 times better than any other automatic I ever drove.
    Has anyone experienced the two? Just want to know what to expect really.
    Cheers,
    Mike
  2. Re: TT S-Tronic vs A3 3.2 DSG?
    Southern County Softy
    20 Post(s)
    Arn't S-tronic and DSG the same thing ?
    A4 2.5 tdi QS (mapped)
  3. Re: TT S-Tronic vs A3 3.2 DSG?
    Feb 2010
    Hants
    Yes I hear they went through a renaming, I know the engine is the same between the two just didn't know if the gearbox was, if it is then happy days!
  4. Re: TT S-Tronic vs A3 3.2 DSG?
    May 2007
    knee deep in clunge
    14 Post(s)
    dsg is not automatic its a manual so please refer to it as a manual.There are no auto gearbox options for tt or 8p a3
  5. Re: TT S-Tronic vs A3 3.2 DSG?
    20 Post(s)
    DSG=Don't Select Gears.
    Do the mechatronic's still fail after the name change...
  6. Re: TT S-Tronic vs A3 3.2 DSG?
    Feb 2010
    Hants
    Talk about picky!! Does it have a clutch? no! I know and so do most other people that its not the same tech as a traditional auto box.
    However try doing a search on Autotrader for a manual gearbox and see how many S-Tronic's and DSG's pop up!!
    Thanks for the informative reply!!
  7. Re: TT S-Tronic vs A3 3.2 DSG?
    20 Post(s)
    It has 2 clutches, just no pedal....
  8. Re: TT S-Tronic vs A3 3.2 DSG?
    May 2007
    knee deep in clunge
    14 Post(s)
    The S tronic 02E twin-clutch gearbox is also known as the Direct Shift Gearbox (DSG) 02E.Yes the mechatronics play up
    Is the S tronic a manual gearbox or an automatic gearbox?
    It is both. The S tronic is an automatic sport gearbox with the emphasis on "Sport".
    The technical basis of the S tronic is a 6-speed-manual gearbox which, as a special feature, has two clutches
    (twin clutch).
    Clutch control and gearshifts are performed by an electro-hydraulic control.
    A twin multi-plate clutch and an intelligent electro-hydraulic control are used allowing two gears to be
    selected simultaneously.
    While driving, one gear is engaged and the matching gear is preselected.
    During gearshifts, the clutch engaging the active gear opens while the other clutch of the preselected gear
    closes. This is done under load and so quickly that power flow is virtually continuous
  9. Re: TT S-Tronic vs A3 3.2 DSG?
    Feb 2010
    Hants
    Sorry I was refering to the pedal, evidently everyone seems to point out the finer details on everything here. (Must be German based?)
    How about answering my original question? No?? I'll try somewhere else then.
  10. Re: TT S-Tronic vs A3 3.2 DSG?
    May 2007
    knee deep in clunge
    14 Post(s)
    Yes that's correct we tend to give the correct answers on this forum
    Power flow
    Engine torque is transmitted via a stub shaft spline
    from the dual-mass flywheel to the twin clutch input
    hub.
    The input hub is welded to the driving disc.
    The driving disc is positively connected to
    outer plate carrier K1, and transmits engine torque
    thus to the twin clutch. Outer plate carrier K1 and
    outer plate carrier K2 are both welded to the main
    hub, so they are in positive engagement at all times.
    Engine torque is transmitted to the two clutches
    at the respective outer plate carriers and, when
    clutch is positively engaged, to the appropriate
    inner plate carriers.
    Inner plate carrier K1 is connected to input shaft 1,
    and inner plate carrier K2 is connected to input
    shaft 2.
    I have driven both and dismantled and rebuilt both.
  1. Audi throws more light on 2011 tt range
    Last Post: 17-04-2010, 10:11 PM
  2. The new generation Audi A3
    Last Post: 28-04-2008, 07:04 PM
  3. World Debut For The All New Audi A3 Cabriolet
  4. Power born from passion The new Audi TT Coupé
    Last Post: 16-06-2006, 07:30 PM
  5. A3 Range Update
    Last Post: 14-02-2005, 11:35 PM
