Thread: 312mm discs
  1. 312mm discs
    Mar 2007
    11 Post(s)
    hi . i am having to replace my front discs due to slight warping . i have been considering upgrading to the 312mm discs so what better time to do it my only problem is locating the correct caliper carriers . my car is a 1.9 tdi 2004 sport avant . at the moment it as 288mm discs now i know i can use these calipers and buy 312mm discs but as anybody got any ideas where i can buy the carriers also what vag group vehicles have these as standard . last but not least as anybody done this upgrade is it worth the effort any info would be very much appreciated
  2. Re: 312mm discs
    Dec 2007
    You need the carriers off a Audi 2.5 or 3ltr
    I tried carriers from a S3/TT and they locating bolts were closer so didn't fit.
    I managed to find a set of 312mm calipers/carriers on ebay from a 2004 2.5 B6 and all is good.
    New from dealer its over £100 per carrier i think!
  3. Re: 312mm discs
    Mar 2007
    11 Post(s)
    Quote Originally Posted by mr singh View Post
    could you tell me if it is worth the effort ie does the braking improve enough to justify the outlay
  4. Re: 312mm discs
    Dec 2007
    When I bought my car the brakes were shot, trully. So I never had a base line on what the OE brakes were like. The 312s have been on for about 500 miles and there bedding in still I think, but there pretty good. I've heard others say there not that much difference but then other VAG cars its quite evident gains.
    They sure look better though, and I'm not lacking any confidence so its all good from me. However with the car being remaped I would be tempted to go for an S4 setup should they come up (I missed a set recently )
    Cheers.
  5. Re: 312mm discs
    Mar 2007
    11 Post(s)
    is the s4 brake set up off the b6 and is it just a bolt straight on job
  1. 312mm brake upgrade
    By Frazzly in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 12-06-2009, 06:43 AM
  2. How easy is it to change the brake discs? 2000W TDI 115 Saloon
    By Androo in forum Passat - B5 Forum - 1997 -2005
    Last Post: 08-05-2009, 07:28 PM
  3. Golf gti 16v (brake discs)
    By peterhall617 in forum Golf MK3 - 1993 - 1999
    Last Post: 20-05-2008, 02:12 PM
  4. PLEASE HELP - Wrong size discs on car!
    By Marco34 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 27-09-2007, 09:32 PM
  5. Mintex brake discs...your thoughts
    By bora(ing) nick in forum Archive posts
    Last Post: 27-09-2007, 02:46 PM
