Thread: Mk5 GT TDI 140 engine shudder at idle
Results 1 to 10 of 35
  1. Mk5 GT TDI 140 engine shudder at idle
    Dec 2009
    Wollaton England
    Does anyone know why the gt tdi engines shudder slightly at idle? Does anyone have a solution to the problem?
  2. Re: Mk5 GT TDI 140 engine shudder at idle
    Mar 2009
    lots of chat on hear about this ! common nusense . i recently had new clutch and fly wheel and it not so noticeable now !
  3. Re: Mk5 GT TDI 140 engine shudder at idle
    Depends if your shudder is constant or intermittent
    - Constant - Flywheel / Clutch etc
    - Intermittant and dissapears with a slight rise in idle revs with a gentle foot on the gas pedal, then Si is right there are lots of threads on here - including recommending a ECU firmware upgrade by the dealer - just about cured it on my TDI 170
    HTH
    Mart.
  4. Re: Mk5 GT TDI 140 engine shudder at idle
    Dec 2009
    Wollaton England
    The engine shuddering only seems to happen when the engine is warm. It never happens when i first drive the car. And it only does it when stopped at traffic lights, traffic jam etc.
  5. Re: Mk5 GT TDI 140 engine shudder at idle
    I'm not a mech (as many on here are), but this defo sounds like:
    - MAF sensor fault , OR
    - You need to look at getting the latest ECU software update from the dealer.
    I got charged £100 diag fee, because I didnt explicitly ask for just the s/w update - and just booked it in to be 'looked at' to see if the misfire/judder could be diagnosed (my warranty is up btw)
    My 57 plate has clocked up about 80k and I noticed that this was getting worse as miles piled on, I understand that on some cars there have been regen issues with the particulate filter - I got misfire at 1500 ish when a regen was happening, and rough running/sluggish as well, that went away during running when the regen finished. (along with the nasty burning smell from the part. filter)
    The latest ECU s/w seems to have made the regen cycle more often, so the effects are less noticable, and I'm happy.
    There are quite a few threads on here about your issue, so best to read up compeltely first, but the ECU update just about cured this and made it ok for me, but I have had a new MAF sensor in the past as well because of this - so you might need both
    People who understand this one. please feel free to chip in and shut me up as I dont actually understand the issue, just wht I did to get it made less of an issue for me 8-)
    HTH
    Mart.
  6. Re: Mk5 GT TDI 140 engine shudder at idle
    Sep 2009
    birmingham uk
    I had this on my 2.0 tdi, it was a intermitant shuddering when the car was idleing, could be quite violent at times. I ve recently had clutch and flywheel and it didnt solve this for me.
    However, the throttle body motor went on mine this week (motor went I think??), and after replacing it the shuddering has gone from my car.
    Cost of the part was 170 quid ish from eurocar parts.
  7. Re: Mk5 GT TDI 140 engine shudder at idle
    Jul 2010
    Lossiemouth
    Ive got a similar problem now on my 04 tdi, the engine is sometimes very rough when idling. Also at 25-30mph it feels like its losing power for a split second every few seconds. I've had the car for 2years and its only done 46k, i've had vw service it twice now and both times theyve found nothing wrong with it!
  8. Re: Mk5 GT TDI 140 engine shudder at idle
    My alternator pulley has been replaced within the last 12 months, but still the tensioner hammers, this only happens when really warm sitting in traffic jams for instance.
  9. Re: Mk5 GT TDI 140 engine shudder at idle
    131 Post(s)
    1976 Post(s)
    It would have the new pulley checked.
  1. help urgent please mk5 golf gt tdi
    By sam-372 in forum Golf MK5 - 2004 - 2009
    Last Post: 31-03-2010, 07:05 PM
  2. mk5 golf gt tdi oil in header tannk, any ideas?
    By sam-372 in forum 2.0TDi - Engine
    Last Post: 30-03-2010, 05:44 PM
  3. A6 (C5) 1.9 PD TDI Oil Change with Pella
    By Col in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 06-10-2009, 09:43 PM
  4. Volkswagen launches new range of highly efficient golf models
    Last Post: 03-07-2009, 07:48 PM
  5. NEW TOURAN AVAILABLE TO ORDER NOW AHEAD OF JANUARY LAUNCH
    Last Post: 04-12-2006, 08:10 PM
