Thread: Mk5 GT TDI 140 engine shudder at idle
Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 35
  1. Re: Mk5 GT TDI 140 engine shudder at idle
    #21
    May 2008
    Finland
    I had a slight judder at idle on my BKD 2.0tdi as well. I got rid of it by cleaning the EGR and installing a new seal with a smaller hole to minimize EGR flow. The seals is VW part number 028 131 547B
    ____________________________________________
    VW Golf Mk.V 2.0tdi 4Motion
    VW Golf Mk.IV 1.4i
  2. Re: Mk5 GT TDI 140 engine shudder at idle
    #22
    135 Post(s)
    2036 Post(s)
    Quote Originally Posted by markyd85 View Post
    I had my alternator tensioner replaced today
    You did not say you had replaced the alternator pulley.
  3. Re: Mk5 GT TDI 140 engine shudder at idle
    #23
    teddy2k5 Guest
    ya as people are saying mines is doing it has done for months an mine has 109 tho on clock full vw service and its never caused a problem still drives perfect
  4. Re: Mk5 GT TDI 140 engine shudder at idle
    #24
    Dec 2006
    I have owned by MK5 GT TDI Sport 2008 golf for a week and it does this... I am new to the MK5 forum having frequented the B7 Audi A4 forum for the last 13 months...
    I bought the golf from a VW dealer and they put 12 months warranty on it for me... but this shuddering is annoying... only when warm, heavy traffic brings it out mostly...
    I thought flywheel maybe?
    Mmmmmmm.... new car... new problems...
  5. Re: Mk5 GT TDI 140 engine shudder at idle
    #25
    Dec 2008
    Glasgow
    I've experienced this in 2 cars (same age 05 reg) - its bit of a shake (a mini earthquake if you like), seems to happen in a cycle, havent really had the patience or the determination to time the shake to see if happens in a certain engine cycle (i.e. after fixed no of mins/secs).
    thanks
  6. Re: Mk5 GT TDI 140 engine shudder at idle
    #26
    Dec 2006
    The VW garage have looked at my car and advised that :_
    "Some of them do this, and some don't, but VW have decided it's something called EGR tickover, and is not something they will fix... apparantly we just have to put up with it... "
    Surely logic would dictate that if some cars do it and others don't then there must be something wrong???
  7. Re: Mk5 GT TDI 140 engine shudder at idle
    #27
    Nov 2006
    if it does it only when the engine is hot its probably a injector
  8. Re: Mk5 GT TDI 140 engine shudder at idle
    #28
    135 Post(s)
    2036 Post(s)
    Probably but I would not like to try and find out which one at £500 each...
  9. Re: Mk5 GT TDI 140 engine shudder at idle
    #29
    Dec 2006
    Maybe VW are not keen on replacing injectors?
  10. Re: Mk5 GT TDI 140 engine shudder at idle
    #30
    135 Post(s)
    2036 Post(s)
    The only way they will replace them under warranty is if Guided Fault Finding identifies it/them as being faulty. Without the print out, VAG will not pay the dealer. It is not as if we even talking a couple of hundred pounds either, four genuine injectors fitted is around a retail value of £2300.
  1. help urgent please mk5 golf gt tdi
    By sam-372 in forum Golf MK5 - 2004 - 2009
    Last Post: 31-03-2010, 07:05 PM
  2. mk5 golf gt tdi oil in header tannk, any ideas?
    By sam-372 in forum 2.0TDi - Engine
    Last Post: 30-03-2010, 05:44 PM
  3. A6 (C5) 1.9 PD TDI Oil Change with Pella
    By Col in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 06-10-2009, 09:43 PM
  4. Volkswagen launches new range of highly efficient golf models
    Last Post: 03-07-2009, 07:48 PM
  5. NEW TOURAN AVAILABLE TO ORDER NOW AHEAD OF JANUARY LAUNCH
    Last Post: 04-12-2006, 08:10 PM
