Thread: airflow flap motor
Results 1 to 10 of 12
  1. Unhappy airflow flap motor
    May 2007
    I have a 2000 tdi 115 pd. I can hear a clicking sound when stationary behind the glove box. i believe this is a faulty airflap motor ? Rather than spend hundreds of pounds getting it fixed, will this cause long term problems if I leave it be and put up with it ? Or is it something i should get fixed straight away ?
    any advice would be helpful
    thanks
    Jun 2006
    UK, Mids
    I this fault happens to everyone sooner or later. I'd just put up with it, mine is stuck open which suits me fine, it it was stuck closed, I'd probaby try and yank it open with a coat hanger. Try putting some fragrance on the pollen filter and see if you can smell it in the car if you aren't sure.
    Apr 2007
    Buxton, Derbys
    Has anyone changed one of these?
    Mine has gone and have the replacement, just not had time to look at it.
    Bertie
    Mar 2007
    Cumbria
    Awful horrible job!!!! But that's just my opinion.I've done a few,hate them.If you have small hands and a bit of patience(unlike me)you could prob have a go.
    A, A
    I reset mine with a VAG COM and it sorted my flap motor out. Below was the error it showed up
    No more clicking and no more hot air only moments.
    Address 08
    Controller: 1U1 907 044 A
    Component: CLIMATRONIC C 2.0.0
    Coding: 11000
    Shop #: WSC 31480
    1 Fault Found:
    01271 - Positioning Motor for Temperature Flap (V68)
    37-10 - Faulty - Intermittent
    Just another B7 Estate
    Apr 2007
    Buxton, Derbys
    I've done the clear codes, etc in Vag-Com but it just comes back.
    Does it really involve taking the whole dash out as I've read? Is there no other way? I have already bought the replacement motor, cost about Ł70.
    And I had half the dash out a month or so ago to retro-fit Cruise Control...
    Bertie
    A, A
    Quote Originally Posted by bertie View Post
    Does it really involve taking the whole dash out as I've read? Is there no other way? I have already bought the replacement motor, cost about £70.
    Bertie
    Have you tried this with your VAG COM:
    Flap Motor Reset
    08 Heater/A.C
    04 Basic settings
    Channel 000 (30 Secs)
    001 (30 Secs)
    002 (30 Secs)
    May 2007
    17 Post(s)
    Bertie
    Yeah, you need to take the full dash out, discharge the aircon and remove a ruddy big metal cross member from behind the dash too. And you still can't see the thing!
    Jim.
    Apr 2007
    Buxton, Derbys
    I'll try the vag-com reset
    Wish the ******* had told me how difficult it was before I offloaded Ł70 to them
    Bertie
    Oct 2005
    Someone took the glovebox out, poked around, cut a wire and all was well again. I'll dig out the post.
    After some digging;
    http://www.passatworld.com/forums/sh...d.php?t=198216
  1. Touran Cooling Fans and 'Intake manifold flap motor problem?
    By Matt B in forum Touran - Sharan - Caravelle
    Last Post: 02-10-2009, 01:09 PM
  2. clicking climate control/eratic airflow
    By Alexandram in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 10-12-2007, 03:42 PM
  3. Mass Airflow Meter
    By sheepsteeth in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 29-05-2007, 01:23 AM
  4. 'W' reg Golf GT TDi - Is it turbo or airflow?
    By Chunkymunky in forum Golf MK4 - 1999 - 2004
    Last Post: 14-03-2007, 05:07 AM
  5. Touran Cooling Fans and 'Intake manifold flap motor problem?
    Last Post: 03-01-2007, 03:55 PM
