Thread: Retrofiting power lid
  1. Retrofiting power lid
    Aug 2009
    ATHENS GREECE
    hello ,am on my way of retrofiting power lid on my ALLROAD A4 2010.i reached a point where after running all wires and testing the motors ,they do rotate up or down but i cannot get the power strike motor to function.i get the folowing error :
    Address 6D: Trunk Elect. Labels: Redir Fail!
    Control Module Part Number: 8K9 827 851 HW: 8K9 827 851
    Component and/or Version: J605 Master H24 0290
    Software Coding:
    Work Shop Code:
    1 Fault Found
    02364 - Closing Assistance
    008 - Implausible Signal
    Freeze Frame:
    Fault Status: 01101000
    Fault Priority: 7
    Fault Frequency: 1
    Reset counter: 132
    Mileage: 28462 km
    Time Indication: 0
    Date: 2010.04.29
    Time: 18:29:12
    i checked all connections with elsa and all is good.do i have to install the motors on the hindges in order to sync with the strike motor ?i whould like to test everything before i do fit the motors to the hinges , in case my boot lid get stuck or sm
    can anyone help with any idea?
    thanks
    ARI
  2. Re: Retrofiting power lid
    May 2007
    knee deep in clunge
    14 Post(s)
    The striker with power latching system must only be installed in the “rear lid closed” position, that is in the same position as a new part would be delivered in.
    If the same striker is re-installed, open the rear lid and block the rear lid lock or rotary latch using a screwdriver or similar tool.
    The power latching system moves to the “rear lid closed” position = basic setting.
    Then unplug the connector from the power latching system. The rear lid lock can be opened again using the handle trim opening mechanism in the rear lid.
  3. Re: Retrofiting power lid
    Aug 2009
    ATHENS GREECE
    Quote Originally Posted by a8 tech View Post
    thanks ,all this is from elsa ,i have it as well.the striker motor is new so it is in close position ,the error is the problem..and should it all function if not connected to the hinges ?(connect the cables and run a test only to see if all functioning prior to install them )
  4. Re: Retrofiting power lid
    May 2007
    knee deep in clunge
    14 Post(s)
    you need to connect the system up then initaite the closing and set adaptions and basic setting so the power latch and motors can be taught in.
    I will look on my vas pc function description for you but it should be the same as 4f allroad and q7,a8.
  5. Smile Re: Retrofiting power lid
    Aug 2009
    ATHENS GREECE
    great ,i will then install all in and ....push the button
    it will be great if you can sent the info of the 4f it looks like it is the same.
    cheers
    ARI
  6. Re: Retrofiting power lid
    Aug 2009
    ATHENS GREECE
    all done
    the problem was with incorect code helper on ross vag com program.the selection of garage opener will activate the striker motor and not the power assist lid option.Selecting power assist lid will activate the option for global pos,sat.
    notified ross ,and they will change it on next sw update.
  7. Re: Retrofiting power lid
    Sep 2011
    Italia
    hello A8 tech, i have a problem after installing the motors on the rear door....the door close to the closed position, but if i want open, the door open only few centimeters. I have calibrate opening with the button on the door, the are two flashing, but seems i must before learn position 0 e 100 for the rear door.
    When i open the door, the counter count up to 100...
    Basic setting is inactive....you can say me what is the trick??
    Thank you
    Guido
  1. Bentley announces detailed specification of new mulsanne
    Last Post: 02-03-2010, 08:11 PM
  2. The efficiency standard – the audi a8 hybrid
    Last Post: 02-03-2010, 07:58 PM
  3. The efficiency standard – the audi a8 hybrid
  4. How does the Quattro system work?
  5. Power born from passion The new Audi TT Coupé
    Last Post: 16-06-2006, 07:30 PM
