Thread: Timing chain noise 2.7 v6 tdi
Page 1 of 10 123 ... LastLast
Results 1 to 10 of 97
  1. Timing chain noise 2.7 v6 tdi
    warrington
    I have an 05 plate A6 2.7 Tdi, which unfortunately over the last couple of months developed what I can only describe as a clatter which lasts for about 2 seconds on start up. I am almost sure that it is one of the chain tensioners losing pressure when the car isnt running, and therefore renders the timing chain slack momentarily on start up. I presume the oil pressure thsn kicks in and actuates the tensioner hence removing the slack.
    Can anyone advise me if this is a common problem, and if any harm will be done if left untreated. Thanks in advance.
    p.s. The car runs beautifully once started, and it only clatters when left for more than about 20 mins
  2. Re: Timing chain noise 2.7 v6 tdi
    May 2007
    knee deep in clunge
    14 Post(s)
    right bank tensioner (os) but very rarely causes any damage.
    The tensioner has been modified so if you purchase a new one it will fine and it can be replaced in situ
    p/n 057 109 218 K
    vag diagnostics, retrofits and general repairs
  3. Re: Timing chain noise 2.7 v6 tdi
    warrington
    Any idea if this can be changed without removal of the engine? Thanks
  4. Re: Timing chain noise 2.7 v6 tdi
    May 2007
    knee deep in clunge
    14 Post(s)
    yes it can be done in situ, allow 3 hours and you need the crank locking tool and camshaft tool
  5. Re: Timing chain noise 2.7 v6 tdi
    warrington
    Thanks for that. Visited the local dealers, and they are quoting 27 hours labour for engine out, etc Do you know of any good technicians that would take on this type of job locally. Cheers
  6. Re: Timing chain noise 2.7 v6 tdi
    May 2009
    Ramsey, New Jersey, USA
    69 Post(s)
    Quote Originally Posted by taximeistergolf View Post
    A8 Tech is fairly close to you geographically, and if he says it can be done with the engine in situ I'd take his word over your local dealers. He may be willing to take the job on if you ask him nicely? Worst case is he says no...
    MF.
    Now: E 53 AMG 4MATIC
    / Q5 2.0TFSi Prestige
  7. Re: Timing chain noise 2.7 v6 tdi
    May 2007
    knee deep in clunge
    14 Post(s)
    I would but I only under take diagnostic and retro fits at the weekend.I would re approach the dealer and ask one of there more technical staff to assist the booking clerk as its 3.7 hours labour to fit.If they are still unsure quote technical bulletin 2012744/6.
    Labour time repair operation number is 15 36 19 44 = 3.70 hours
    Please do not take a copy of this with you but simply explain this to the booking clerk who will double check for you and confirm the cost.
    Allow extra cost for the gaskets etc
    2 3 0
  8. Re: Timing chain noise 2.7 v6 tdi
    May 2009
    69 Post(s)
    Quote Originally Posted by a8 tech View Post
    I would but I only under take electrical and retro fits at the weekend.I would re approach the dealer and ask one of there more technical staff to assist the booking clerk as its 3.7 hours labour to fit.If they are still unsure quote technical bulletin 2012744/6.
  9. Re: Timing chain noise 2.7 v6 tdi
    Ribble Valley
    Hi, did u manage to sort out your problem? ive seemto have the same problem on my A8 tdi. cheers
  10. Re: Timing chain noise 2.7 v6 tdi
    warrington
    Well, what a timely question. After weeks of dragging my heels I finally had to stump up 120 hard earned folding for main ******** to examine the car.
    The prognosis is either a guaranteed fix in the region of £3500, or an unguaranteed fix of approx £750. For this lower amount they are going to replace the top tensioner (which is a known problem to them). It is going in this Monday 19th July, and I am leavimg it with them until I return from my hols on 2 August. I will let you know how it goes. Cheers Graham
  1. Experiences of the 3.0 TDI vs 2.7 TDI
    By Dans in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 01-09-2012, 10:45 AM
  2. 2.0 TDI (170) vs. 2.7 TDI (180)
    By skywalker1 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 22-02-2010, 09:18 PM
  3. Intense TDI power - The Audi A3 TDI clubsport quattro
    Last Post: 18-05-2008, 10:12 AM
  4. Intemittent loud noise from radiator area
    By TBird1 in forum Passat - Archive Topics
    Last Post: 09-02-2007, 03:20 PM
  5. New 2.7 TDI Model boosts Audi A6 Saloon range
    Last Post: 24-11-2004, 09:00 PM
