Thread: upper front control arms
Results 1 to 10 of 14
  1. upper front control arms
    Mar 2010
    Inverness
    im in the process of tracking down an annoying knocking noise coming from the osf of my avant. i know these cars eat suspension arm bushes so im putting it down to that.
    ive changed the lower arms and drop link and would like to change the uppers.
    do you have to disconnect the plate that holds the strut to the inside of the inner wing and lower it in order to remove the bolts on the inboard side of the arm?
    cheers
  2. Re: upper front control arms
    Sep 2008
    6 Post(s)
    Quote Originally Posted by DGT View Post
    cheers
    Have done this job on a B5 model, and I had to drop the strut down to access bolts.
    2016 BMW i3 REx (80k)
  3. Re: upper front control arms
    Mar 2010
    Inverness
    cheers for that.
    are all the bolts accessed from under the bonnet?
    thanks again
  4. Re: upper front control arms
    Sep 2008
    6 Post(s)
    Yes, you'll need spring compressor, etc. Link here. http://audizine.com/forum/showthread...al-and-Install
  5. Re: upper front control arms
    Mar 2010
    Inverness
    nightmare job. bolt on Track control rod end wont come out..looks like its supposed to be captive? also i managed to shear the bolt that goes through the clamp that holds the ball joints of the upper arms in place!
  6. Re: upper front control arms
    Sep 2008
    6 Post(s)
    Aye it's a nightmare of a job. When I did it, I couldn't shift the pinch bolt that holds the upper control arms. After 2 days of banging it with a lump hammer, numerous cups of tea and much swearing - it was still stuck solid. Ended up getting the mechanic at my work to use an oxy/acetylene torch to heat it up and knock it out. Suspect - this is what you'll have to do. Upper arms will be goosed as a result. Audi have a special tool for removing the pinch bolt, bit like a ball joint removal tool.
    Regards the tie-rod end, spray Duck Oil penetrating release on it before attempting the job. Still no success, then torch this off too.
    Worked on my wife's A2 O/S front coil spring a couple of weeks ago, it was a bleed'n nightmare too. ARB link was siezed and tie-rod bolt refused to budge. Ended up cutting it off. I hate suspension jobs - they always take longer than anticipated.
  7. Re: upper front control arms
    Mar 2010
    Inverness
    that makes me feel a wee bit better.
    dissimilar metals eh
    im gonna attempt to hacksaw out as much of the bolt through the top arm as i can see and hope i get most of the section of the bolt that is holding the ball joint..sounds like a long shot but i dont have access to decent heating gear. Suppose i could get a blow torch on the alloy as it should expand a fair bit quicker than the bolt,,maybe
    found this, think its slightly different but it goes to show how much easier the yanks have it with their climate http://www.audiworld.com/tech/wheel43.shtml
  8. Re: upper front control arms
    Sep 2008
    6 Post(s)
    Personally I'd just drive it to a local garage and get them to heat it. It's a complete pain - hitting it for hours on end. Because the bolt has probably been there for a number of years, it's effectively fused in position. Get a new pinch bolt from Audi so you can replace it afterwards. Use a little copper ease or marine grease (Duckhams) before reassembling. After the winter we've just had - it's a wonder everything hasn't rusted solid.
  9. Re: upper front control arms
    Mar 2010
    Inverness
    blind determination yesterday. i cut off the arms at the ball joint, sop im left with parts of the pinch bolt and the tapered section of the ball joints left to remove. gonna try my blowtorch on it tonight
  10. Re: upper front control arms
    Sep 2008
    6 Post(s)
    Keep us posted as to your progress.
  1. Lamborghini gallardo lp 570-4 superleggera
    Last Post: 02-03-2010, 08:17 PM
  2. Lamborghini gallardo lp 570-4 superleggera
  3. Greener New Generation Audi A3 Range Majors On Efficiency
    Last Post: 10-05-2008, 01:37 PM
  4. Replies: 0
    Last Post: 01-08-2007, 08:28 PM
  5. Option Codes
    By Samcat in forum Passat - Archive Topics
    Last Post: 23-11-2006, 11:25 AM
