Thread: Remote Centrol locking
  1. Remote Centrol locking
    Dec 2008
    Fob has decided to stop working completely, changed battery to no avail. Tried to re-programme as per manual but won't have it. Any suggestions?
    Spare key is off to Audi today to be coded, will see if this fob works later. Meanwhile I'm back to using the key, etc
  2. Re: Remote Centrol locking
    Aug 2009
    Near Lanark
    21 Post(s)
    PKDO
    Mine did the same and I searched the internet and found this on another forum
    -if the vehicle is locked,use the key to unlock the door
    -press the unlock button on the remote control
    -insert the key into the ignition and switch on the ignition
    -switch off the ignition and remove key
    -press the unlock or lock button.
    it should now be re-synchronised
    It claimed to be from the manual but I never checked so it may be something you've already tried.
    I did the above with both my fobs after changing the batteries and it worked for me - both work perfectly now.
    A6 C7 Saloon 3.0Tdi Quattro S Line | 242bhp | Quartz Grey
    2016 Triumph Street Triple | 106bhp | Pearl White
    VCDS owner - Lanarkshire Area. PM Me if you need help.
  3. Re: Remote Centrol locking
    Mar 2010
    Manchester
    I know this thread is a bit old now, but thought I'd post anyway!
    Exactly the same has happened to me (2006 18T cab). Had a roof warning light at the same time and local indie reckoned it was a failing roof sensor causing the locking to malfunction.
    Roof light has cleared following a reset of the fault codes, so I guess he was wrong. It's due back in on Wednesday - here's hoping.....
  1. B5 A4 Central Locking FAQ
    By ini in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 01-09-2015, 11:46 AM
  2. Wiring remote locking kit to 1999 vw caddy van
    By caddyman! in forum The Commercial Range
    Last Post: 17-09-2009, 11:05 PM
  3. Problems connecting Remote Central Locking ...2004 Polo E
    By andy4976 in forum Polo - Derby - Lupo - Fox
    Last Post: 29-06-2009, 10:24 AM
  4. do all boras have remote centrol locking
    By craig8661 in forum Bora - 1998 - 2005
    Last Post: 13-04-2008, 01:20 PM
  5. Remote locking and alarm problem
    By Jo L in forum Archive posts
    Last Post: 12-12-2006, 08:59 PM
