Thread: Can I clean the throttle body without removing it?
  1. Can I clean the throttle body without removing it?
    Apr 2009
    Hi everyone, CAR: Golf MK3 1.4CL AEX
    Replaced my air filter the other day [which was filthy with oil and gunk] and saw that the throttle was fairly crudey as well. So I had a 5 second google and found carb cleaner as the answer.
    So after getting home from halfords with the spray I got cold feet about the logistics of it all so here's the question:
    Can I simply clean the throttle body without removing it i.e. by spraying onto a cloth and wiping the gunk off? And would this do anything at all?
    So if I can't do it this way I will take it out and clean it I guess. But:
    >will I have to do a reset to erase the learnt values i.e. will it end up idling at 2000rpm? [Crasher mentioned this in a post I saw earlier]
    >And is there anything else I should watch out for?
    Cheers,
    K
  2. Re: Can I clean the throttle body without removing it?
    Apr 2009
    OK so found this thread I should have read first:
    Throttle Body Cleaning 1.6 AEE
    https://www.vwaudiforum.co.uk/forum/s...tle+body+clean
    So this guide is for an AEE 1.6 I presume this should work for mine.
    If anyone has any caveats please let me know, I'll post how I get on as well
  1. A4 B5 throttle body reset problem with VAG
    By adrianwillis in forum VCDS - General Questions
    Last Post: 09-09-2011, 12:12 PM
  2. Question Audi A3 S reg. 1.6 Erratic iddle and poor starting, Throttle Body? or ?
    By win2kpro in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 08-04-2010, 11:11 AM
  3. Throttle Body Conversion HELP NEEDED!!!
    By gtxi in forum South West England
    Last Post: 18-12-2009, 08:06 PM
  4. Question Throttle body clean 2.8 V6
    By Frenchman in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 16-07-2009, 10:29 PM
  5. 1998 B5 - Hunting Idle after Throttle Body Cleaning
    By ectwo in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 02-05-2008, 05:53 AM
