Thread: Unidentified Component
  1. Unidentified Component
    Dec 2009
    Mobberley England
    Hi folks...I was rooting around under my rear seat yesterday and discovered that the ABS relay hides under there, along with a larger silver box with several vacuum pipes and some electrical connectors. Does anyone know what function this performs???....I thought it may be related to the central locking system!?
    Cheers....
  2. Re: Unidentified Component
    Gwent
    If it's not the ABS ECU, then possibly the control valve for the difflock?
    2001 Passat Sport tdi 130hp
    1990 Audi coupe 20v x 2
  1. Audi a8 2003 Current gearshift program problem
    By eints77 in forum VCDS - Help Requests
    Last Post: 20-07-2010, 02:58 PM
  2. Esp malfunction/parking brake
    By BIGSSS in forum VCDS - Help Requests
    Last Post: 21-01-2010, 01:52 PM
  3. Problems with Nav retrofit MMI A6 2008
    By craiglett in forum In Car Entertainment
    Last Post: 31-12-2009, 11:27 AM
  4. low engine power from cold
    By saabsalltheway! in forum VCDS - General Questions
    Last Post: 30-11-2009, 10:21 PM
  5. Healp needed VAG com
    By Snooze1 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 18-06-2009, 07:47 AM
