Thread: Broken dipstick housing
Page 1 of 3 123 LastLast
Results 1 to 10 of 21
  1. Broken dipstick housing
    Apr 2010
    United Kingdom
    Where can I get a new housing for the dipstick as the old one had became very brittle and broke off. Also is it easy to connect back in.
  2. Re: Broken dipstick housing
    Southern County Softy
    20 Post(s)
    The orange plastic tube ?
    Available from a dealer, it clicks into position.
    A4 2.5 tdi QS (mapped)
  3. Re: Broken dipstick housing
    Apr 2010
    United Kingdom
    cheers
  4. Re: Broken dipstick housing
    Mike McKinstry Guest
    Is there an o ring anywhere near the base??
    Would like to know as seem to have an oil leak at base of dipstick.
  5. Re: Broken dipstick housing
    Apr 2010
    United Kingdom
    didn't see one
  6. Re: Broken dipstick housing
    133 Post(s)
    1982 Post(s)
    Don’t buy on online dip stick guide tubes, they don’t fit and cost more (inc. postage) than from a dealer.
  7. Re: Broken dipstick housing
    Apr 2010
    United Kingdom
    thanks crasher, got one from the dealer today. cheers
  8. Re: Broken dipstick housing
    How do these fit-I have alot of oil at base of dipstick and am wondering if it is from this or from the gasket between oil filter housing to block??
    Anybody had a leak in this area-the oil also seems to be spraying along block nearly as far as directly under oil feed to turbo union bolt which made me think this was leaking but all dry around bolt.
    Mike
  9. Re: Broken dipstick housing
    Guys,
    Could you tell me how to go about fitting a dipstick guide tube-and removing the old one-think this may be the cause of my oil leak??
    many thanks,
    Mike
  10. Re: Broken dipstick housing
    133 Post(s)
    1982 Post(s)
    Getting the bits of the old one out is awkward, I use a pick and a vacuum cleaner as you don’t want the bits in the sump. Fitting a new genuine unit is just a case of pushing it on an a quick bit of force to seat it, ter is no O ring or seal on the metal tube or plastic guide.
  1. why oil leak from top of dipstick
    By tiredeyes69 in forum Golf MK4 - 1999 - 2004
    Last Post: 04-02-2011, 09:21 PM
  2. cracked thermostat housing!
    By cara_essex in forum Golf MK3 - 1993 - 1999
    Last Post: 15-05-2008, 06:34 PM
  3. Broken engine oil dipstick
    By Abbs985uk in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 04-02-2008, 09:50 AM
  4. Replacing a Broken wing mirror on a Sharan (housing and all)
    By JReed in forum Touran - Sharan - Caravelle
    Last Post: 12-12-2007, 10:34 PM
  5. Shattered dipstick collar
    By stevem999 in forum Passat - Archive Topics
    Last Post: 19-01-2007, 08:25 PM
