Thread: Mk3 Golf Engine Stalls
  1. Mk3 Golf Engine Stalls
    Feb 2006
    I have a 95/96 Golf GTi 2.0
    Everytime the car comes to a stop the engine hessitates and then stalls when the clutch is put down fully. When Cold the engine initialy is a bit hessitant but after 30 seconds this goes away and driving over 1500 rev's is fine and smooth.
    The car has had a fairly recent, full service and has had the sensor changed in the exhust outlet.
    I drive in alot of heavy traffic to and from work and as you can imagine it's a nighmare to have to keep the revs up at all times or suffer a stall, then to start the engine for 30th time that trip and hope that nobody noticed.
    One good thing is that the car will always start again.
    Someone please have a miracle cure as round-a-bouts are a life or death experence.
    Any help with this would great
    Feb 2006
    Nottingham
    possible idle control valve(sometimes known as 'stepper motors')
    ether that or air flow meter/ecu?
  3. Thanks
    Feb 2006
    Thanks for the advise.
  4. Sorted
    Feb 2006
    The problem was the oxgen sensor on the exhust outlet. It had been changed before for a non VW part has must of been of a very poor quality. Now I have had a nice expensive German part fitted it is running 200% better. I also had a good clean out of mostly every thing and found alot of gunk!!! Nice!!!
    I'm going to run some fuel treatment though the engine and hopefully that should get rid of any further little murmors.
    Thanks.
    JL
  1. a3 starts and stalls
    By dolly in forum Audi A3 - Archive Topics
    Last Post: 05-06-2007, 06:01 PM
  2. Golf Mk4 1.6 Revs Fluctuate / stalls / temp up & down!!
    By randall977 in forum Golf MK4 - 1999 - 2004
    Last Post: 15-04-2007, 01:29 PM
  3. AHF Golf engine
    By dreamworx in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 26-03-2007, 10:15 AM
  4. Engine Oil for Mk 4 Golf
    By Reet in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 14-12-2006, 02:28 PM
  5. 1991 80SE Nearly stalls after ignition ?
    By tattersfield in forum 80 - 90
    Last Post: 25-10-2005, 11:19 AM
