Thread: Blocked bulkhead
  1. Blocked bulkhead
    middlewich uk
    After cleaning my car today i noticed that there was about 2" of water in the bulkhead due to the drain holes being blocked, i tried to unblock them but could not reach them without removing the battery so had a feel around under the bulkhead and found a large rubber bung which i have now removed to stop the water building up, it is just to the left of the battery if any body else id having this problem
  2. Re: Blocked bulkhead
    131 Post(s)
    1978 Post(s)
    This problem is probably THE most covered issue on the A4 and Passat. The problem with removing the bung/drains is that when you turn on the heater blower, fumes from under the car can be sucked into the heater and do not smell very nice and on a petrol engine, if there is an exhaust leak these fumes could contain dangerous levels of carbon monoxide.
  1. Plenum Chamber Blocked
    By Peter D in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 03-06-2011, 02:52 PM
  2. A4 bulkhead drainage bungs
    By cjboddy in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 22-03-2010, 10:51 PM
  3. Routing electrical cables through the bulkhead
    By chris_r in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 27-12-2009, 07:57 PM
  4. Bulkhead filling with water
    By renedrag in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 07-08-2009, 07:12 PM
  5. Question Routing a pipe through the bulkhead
    By staffords in forum Audi A3 - Archive Topics
    Last Post: 16-04-2009, 07:42 PM
