Thread: bleed screws in cooling system
  1. bleed screws in cooling system
    Dec 2009
    dundalk ireland
    My heater aint'nt working too good on my 2004 touran 2.0 tdi. Could be air trapped somewhere. Are there any air bleed screws in the system?
    rgds
  2. Re: bleed screws in cooling system
    Aug 2008
    hi
    if the system is laid out the same as the passat/A6 the point to bleed out trapped air is where the coolant hoses pass through the bulk head to the heater matrix. the left hand hose has a small hole in it, you have to release the hose clip and partially pull the hose off the tail to vent to atmosphere through the small hole.
    a good idea is to remove the fixings for the expansion tank and elevate as much as possible so as to let gravity force the coolant through the system and expel the trapped air.
    hope this helps a little................ mark
  3. Re: bleed screws in cooling system
    135 Post(s)
    2042 Post(s)
    There are no bleed screws on the Touran, this is the Passat section.
  1. Bentley announces detailed specification of new mulsanne
    Last Post: 02-03-2010, 08:11 PM
  2. Bentley announces detailed specification of new mulsanne
  3. The Audi e-tron
    Last Post: 02-10-2009, 07:30 AM
  4. The Audi e-tron
    Last Post: 15-09-2009, 08:34 PM
