Thread: Another airbag light problem
Results 1 to 9 of 9
  1. Another airbag light problem
    Feb 2010
    Cambridge
    Hi, I have a strange problem with my 02 A4. Ive searched but cant find anyone with the same symptoms.
    The light came on and is on for 80% of the time. Occassionally it will go off and stay off for the duration of the journey, however if I turn the ignition off and on again it comes back on!
    I had someone try to diagnose it, but he said he couldnt talk to the Airbag module so I needed one of those costing around £600. However after telling him that it does go off sometimes he wasnt too sure.
    Anyone got any ideas what it could be?
  2. Re: Another airbag light problem
    The fault may be with his diagnostic tool,that he is unable to enter the unit,i suggest you get someone else to read a fault code for you.before spending £600
  3. Re: Another airbag light problem
    Jan 2010
    Cornwall
    Mine became intermittant for a few days and hasnt been on since. I fiddled with wires under the drivers seat as I had a drinks bottle end up underneath so hoping it was something mystical but would be interested to see what you find
  4. Re: Another airbag light problem
    Feb 2010
    Cambridge
    I have had a little play under the seats, but will play some more just incase. I can just see the airbags exploding.
  5. Re: Another airbag light problem
    Jul 2008
    Bristol
    I too have the same problem I was told that I need to replace the Airbag sensor which will cost around £70 or £80 from an Indi!!
  6. Re: Another airbag light problem
    Nov 2008
    N/A
    Definately get it plugged into a dealer diagnostic system (expensive) or get someone with vcds to run a scan for you... then you'll know for sure. There is a common problem in the VAG range with the wiring under the front seats becoming worn over time, but there's no way to know for sure without a scan.
    Don't worry about airbags going off, when the airbag warning is on in the dash, all airbags are automatically disabled for safety's sake - don't want them going off whilst someone is driving.
  7. Re: Another airbag light problem
    Feb 2010
    Cambridge
    Thanks for your help, its booked in to the local indi so fingers crossed its not gonna be too bad
    Benjie, can I ask where you got you rs4 arb from and how much it cost. I need to replace mine and have seen people on here saying it costs around £80 but cannot find it for less than £200.
  8. Re: Another airbag light problem
    I had a similar issue. Was on and off. Sacn said front crash sensor I think, but it went off, and has stayed off since. One bit of good luck!
  9. Re: Another airbag light problem
    Feb 2010
    Cambridge
    Well im glad I took your advice and got a second opinion. It turns out its a crash sensor, still gonna cost over £100, but not as much as the first guy scared me with
  1. Rear fog light / reverse light fault (golf 5)
    By 85turbo in forum VCDS - General Questions
    Last Post: 03-09-2010, 11:30 PM
  2. Question should my car have brake pads wear indicator?
    By lucianus in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 04-05-2009, 12:19 PM
  3. 1996 a4 airbag light reset
    By pogues in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 23-08-2008, 05:46 PM
  4. Advice about poss recurring problem
    By chicka in forum Golf MK4 - 1999 - 2004
    Last Post: 17-04-2008, 05:58 PM
  5. Problem with ABS on Polo 2001 1.4L
    By lyonelk in forum Polo - Derby - Lupo - Fox
    Last Post: 12-08-2006, 09:08 AM
