Thread: Brake light showing on dash.
Results 1 to 10 of 14
  1. Brake light showing on dash.
    Apr 2010
    Sunbury-on-thames UK
    I have a A4 2.5 quattro estate and I topped up the brake fluid and every since it has the brake warning light in the middle of the dash, My brakes are all working fine all the pads have plenty of wear left I am just wondering if there is a sensor how I can fix this problem..
    Many Thanks
    Mike
  2. Re: Brake light showing on dash.
    Dec 2007
    Quote Originally Posted by madmikee View Post
    Many Thanks
    Mike
    sensor ir on the pads
    check concetion they always come apart
  3. Re: Brake light showing on dash.
    Jul 2008
    stoke on trent
    is it a big red exclamation mark with 3 bleeps?, pad warning is orange and appears in top window
    might be problem with fluid level sender?
    99 a4 b5 1.8tqs saloon
    99 a4 b5 2.5tdi avant
    90 eunos roadster
  4. Re: Brake light showing on dash.
    Apr 2010
    Thanks will check both and let you know how it goes cheers
  5. Re: Brake light showing on dash.
    Armitage, Rugeley, Staffordshire
    My 2001 tdi is also showing the brake warning sign in the top part i have checked the pads and they are fine and i made sure the connectors where fully made and its still doing it
  6. Re: Brake light showing on dash.
    Mar 2010
    notts u.k
    check your brake fluid level
  7. Re: Brake light showing on dash.
    Jul 2008
    stoke on trent
    Quote Originally Posted by Ian1971 View Post
    the pad warning can be permantly disabled with vagcom (if its full screen dis) your not too far if you wanted it doing
    had to do mine when i fitted s4 hubs/brakes as they had no connections
    low fluid would be a red exclamation mark full screen
    90 eunos roadster
  8. Re: Brake light showing on dash.
    Quote Originally Posted by olds_kool View Post
    Its not low on fluid when i got it the level was high and its only since dropping it to the correct level its started with the warning. Where abouts are you fella?
  9. Re: Brake light showing on dash.
    Dec 2007
    post details to disable pad warning
    i need to do this on a car im sortin out
    cheers
    iv searched vcds and cant find out how to disable it
  10. Re: Brake light showing on dash.
    "I topped up the brake fluid and every since it has the brake warning light in the middle of the dash..."
    Linking one thing with the other, I'd guess you have pulled a wire off somewhere on the sensor which is built into the brake fluid reservoir cap - OR - if it has a moving float thing like my Sharan maybe it is jammed in the down / extended / low-level position.
    Hope this helps. OD
  1. Replies: 23
    Last Post: 20-11-2011, 06:44 PM
  2. Brake pad warning light
    By Wee Baldie in forum Alhambra
    Last Post: 14-10-2010, 07:10 PM
  3. Rear fog light / reverse light fault (golf 5)
    By 85turbo in forum VCDS - General Questions
    Last Post: 03-09-2010, 11:30 PM
  4. Question P0571 brake light switch epc
    By tiredeyes69 in forum Golf MK4 - 1999 - 2004
    Last Post: 11-10-2009, 01:19 AM
  5. help - problems with my brake lights!
    By katy in forum Golf MK4 - 1999 - 2004
    Last Post: 18-12-2007, 01:01 PM
