Thread: Vag com fault 01435 & 00588
Results 1 to 10 of 11
  1. Vag com fault 01435 & 00588
    Tullamore, Ireland
    I had the ESP/ABS/Glow plug warning lights appear on thursday evening on the way home. Checked my brake lights and they were not working. Ran Vag com and had a 16955 fault so I replaced my Brake switch at the top of the brake. Glow plug light is now out, brake lights are working but the ABS/ESP lights are still on and yesterdaty the Airbag light came on.
    Ran vag com today and found I have 01435 & 00588 faults. According to Ross Tech wiki, I found the following on 01435 fault:
    Possible Causes
    * Basic Setting not performed
    Possible Solutions
    * Perform Basic Setting
    I assume that since I changed the brake switch I have to perform some settings using Vag com.
    My first question is: How do I perform these basis settings?
    My second question is: Would the Airbag fault be related to the Brake basic settings that I have to perform?
    Again, according to Ross Tech wiki, I found the following on 00588 fault:
    Possible Causes
    *Wiring from/to Airbag Igniter Driver Side (N95) faulty
    *Coil Spring with Slip ring (F138) faulty
    *Airbag igniter Driver Side (N95) faulty
    Any help would be greatly appreciated.
    Mark
  2. Re: Vag com fault 01435 & 00588
    Tullamore, Ireland
    Update on this, I changed out the slipring yesterday and cleared all faults. The airbag fault has not come back but the ESP & ABS lights are still on. The same fault code 01435 is appearing under module 03 - ABS breaks.
    Does anyone know how to carry out the Basic Settings using Vag Com?
  3. Re: Vag com fault 01435 & 00588
    warp_speed Guest
    Not 100% sure your slip ring was the problem, the fault codes you have now is the ones I got when I fitted cruise control, I had to remove the steering wheel, slip ring, etc.
    Anyway the module has lost the steering angle for the ESP so the module doesn't know what position the steering wheel is at. I turn the steering lock to lock and go for a short drive, this normally calibrates the steering and should resolve your issue I hope.
    I'm sure someone might come along to correct me if I'm wrong
  4. Re: Vag com fault 01435 & 00588
    Dec 2007
    Quote Originally Posted by fulcrum111 View Post
    it tells you how to do basic settings in vcds wiki
    this is for bosch 5.7
    Basic Setting
    Steering Angle Sensor (G85) Calibration
    [Select]
    [03 - ABS Brakes]
    [Fault Codes - 02]
    [Done, Go Back]
    Turn steering wheel at least 30 ° left and back straight ahead.
    [Meas. Blocks - 08]
    Group 005 Field 1 (Steering Angle Sensor -G85-)
    Specification: 0.0 °
    Tolerance (when straight): ±5.0 °
    [Done, Go Back]
    [Login - 11]
    Enter 40168
    [Do It!]
    [Basic Settings - 04]
    Group 001
    [Go!]
    [Done, Go Back]
    [Fault Codes - 02]
    All fault codes should have disappeared.
    [Done, Go Back]
    [Close Controller, Go Back - 06]
    or bosch 8.0
    From Ross-Tech Wiki
    Jump to: navigation, search
    Basic Setting
    [Select]
    [03 - ABS Brakes]
    [Fault Codes - 02]
    [Done, Go Back]
    Start Engine (session still running).
    [Meas. Blocks - 08]
    [Done, Go Back]
    [Security Access - 16]
    Enter 40168
    [Do It!]
    Group 001
    [Go!]
    [Done, Go Back]
    [Fault Codes - 02]
    [Done, Go Back]
  5. Re: Vag com fault 01435 & 00588
    Tullamore, Ireland
    Thanks for the responses guys but the steering angle is not the problem. I reset the steering angle after installing the replacement slip ring. True, when I checked the fault codes after resetting, all faults had gone but then fault 01435 comes back.
    I'm sure its related to changing out the brake switch as I haven't touched anything else!
  6. Re: Vag com fault 01435 & 00588
    Nov 2008
    N/A
    Have you read this?
    http://wiki.ross-tech.com/wiki/index.php/01435
    It says to change the brake pedal switch an a few other things.
  7. Re: Vag com fault 01435 & 00588
    Dec 2007
    you dont need to reset anything when you change the brake switch
    have you checked all your brake light bulbs
    that code relates to the switch
    or the brake presure sensor 1 (G201)
    01435 - Brake Pressure Sensor 1 (G201)
    01435 - Brake Pressure Sensor 1 (G201): No or Incorrect Basic Setting / Adaptation
    Possible Symptoms
    • Malfunction Indicator Light (MIL) active
    Possible Causes
    • Basic Setting not performed
    Possible Solutions
    • Perform Basic Setting
    01435 - Brake Pressure Sensor 1 (G201): Electrical Fault in Circuit
    Possible Causes
    • Brake Pedal Switch (F) faulty/jammed
    • Brake Pressure Sensor 1 (G201) faulty
    Possible Solutions
    • Check/Replace Brake Pedal Switch (F)
      • See Measuring Blocks
    • Check/Replace Brake Pressure Sensor 1 (G201)
      • ABS Hydraulic Unit (N55) may need to replaced
      • Perform Brake Pump Bleeding
      • Perform Brake Pressure Sensor 1 (G201) Basic Setting
      • Replace Brake Electronics Control Module (J104)
    • so thats what the code means
  8. Re: Vag com fault 01435 & 00588
    Tullamore, Ireland
    Thanks Benjie & Bez, I had seen that.
    All my bulbs are working - thats why I'm putting it down to "Basic setting not performed" and wondering how to do the basic setting. There are instructions in the Ross Tech wiki for performing basis setting for the ABS brakes - I've done this and still no joy. I don't think its the ABS Hydraulic Unit or brake bleeding as the fault only came up after I replaced the brake pedal switch. Maybe the replacement switch is causing the problem?
  9. Re: Vag com fault 01435 & 00588
    Dec 2007
    yep maybe the switch
    i did my daughters A3 and it chucked the light on went to audi and swapped it all was good with second 1
  10. Re: Vag com fault 01435 & 00588
    Nov 2008
    N/A
    My MkIV has operational brake lights but a symbol on the dash - chenged it and it went away.
    It can't hurt to do the basic setting thing you speak of, though I have no clue about it I'm afraid!
  1. Problems with Nav retrofit MMI A6 2008
    By craiglett in forum In Car Entertainment
    Last Post: 31-12-2009, 11:27 AM
  2. alarm fault codes
    By A6TYY in forum VCDS - Help Requests
    Last Post: 17-08-2009, 08:01 PM
  3. 2006 A6 Battery issues
    By wmccann in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 04-04-2009, 04:08 PM
  4. 05 Audi A4 2.0 TDI problems
    By Dent Reform in forum VCDS - General Questions
    Last Post: 12-05-2008, 09:18 PM
  5. Are And Vag Com / Vag Tacho The Same
    By davecoz in forum VCDS - General Questions
    Last Post: 21-11-2007, 09:13 AM
