Thread: 'Leaking' engine mount
  1. 'Leaking' engine mount
    Apr 2010
    Blackpool, Lancashire
    Hi All,
    I've had the fun task of removing the sump from my A6 Tdi this week, and during the process found that one of the engine mounts/dampers appeared to be leaking a red oil.
    Having googled the various terms that I could think of, there's not much to tell me if the mounts do actually contain oil or I'm just going nuts.
    Can anyone advise? Does a leak mean replacement? Are there any considerations I should be making while I'm stripped?
    Thanks!
  2. Re: 'Leaking' engine mount
    Are you referring to a mount or the torque reaction support at the front of the engine. Some TDI mounts have an elastomeric fluid in them to damp down the low end frequencies. How thick is the fluid. There are not repairable. Regards Peter
  3. Re: 'Leaking' engine mount
    Apr 2010
    Hi Peter,
    Thanks for the quick response.
    It's one of the engine mounts: http://www.autohausaz.com/secure/Par...8D0199379K.jpg
    The fluid is quite thick, I would guess at a damping fluid rather than a lube.
    Oddly, the driver's side mount looks different to the opposing side, and also has a dust cover. I wondered if a previous owner might have replaced it with an upgraded, aftermarket version.
  4. Re: 'Leaking' engine mount
    Apr 2010
    According to ebay - which appears to have some - it's a 'hydro-mount', although they only seem to be for the right hand side. Is it likely that only one is 'hydro', because of the direction of spin of the crank?
  1. Engine Mount Valve 2.5tdi
    By nanafagis in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 21-11-2009, 12:04 AM
  2. vr6 engine mount help please
    By probert993 in forum Golf MK3 - 1993 - 1999
    Last Post: 16-11-2009, 12:51 AM
  3. oil warning signal
    By ger83 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 04-11-2009, 07:20 PM
  4. A4 Quattro Servicing Tasks
    By MrBeardy in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 08-08-2007, 04:57 PM
  5. Replies: 0
    Last Post: 01-08-2007, 08:28 PM
