Thread: Engine management light and misfire
Page 4 of 4 FirstFirst ... 234
Results 31 to 40 of 40
  1. Re: Engine management light and misfire
    #31
    Jan 2009
    I know you are right, but was planning to do the exhaust valves, guides x 6, valve seals x6, headset, head bolts and re-use the timing chain as am on seriously tight budget!!
    Car has done about 77K...
  2. Re: Engine management light and misfire
    #32
    135 Post(s)
    2026 Post(s)
    So you won't be upset if the hydraulic compensation elements pump up and smack a valve into a piston or the chain jumps a tooth or three and does the same? I do the full Febi kit for £119 or the basic kit for £80 if the gears are not worn, a set of Febi lifters is £40.55 and a set of fingers £56.21.
    0 2 0
  3. Re: Engine management light and misfire
    #33
    Jan 2009
    Well that would be slightly annoying :-)
    What do you think about the reconditioned head services on fleabay for £225?
  4. Re: Engine management light and misfire
    #34
    135 Post(s)
    2026 Post(s)
    I would rather use a local engineer. When we do them we try and get people to have a VAG exchange head but this gets more difficult to justify as the car ages. Three valves, three guides and a skim would be about £150 at most engineers, that is all there is to a recon head, the rest is dressing.
  5. Re: Engine management light and misfire
    #35
    Jan 2009
    Crasher, thank you for your help and advice on this...
  6. Re: Engine management light and misfire
    #36
    Oct 2016
    Croatia
    Hello everyone, especially Crasher who is always helping out
    Yesterday I encountered a similar (if not the same) problem discussed here.
    I have a 2007 VW polo 1.4 TDI Bluemotion with around 130.000km
    Yesterday I had a main belt change (complete kit) and an oil change.
    5 minutes after I drove out of the mechanic garage I noticed the glow plug/engine management light flashing (blinking) and a reduced power to the engine. The engine did not stutter, it just did not accelerate as it did before.
    I called up the mechanic who did the work and he said that I should try turning off the car and then back on. After I did it, the glow plug/engine management light stopped flashing. However today, while driving to work it started again.
    I read from one of Crashers posts:
    "It often happens if oil changes have been neglected or unfortunately (for the mechanic doing the job) just after an oil change. I am always extremely cautious with the 3 cylinder engines when doing an oil change, I like to crank them over plugs out (coil packs disconnected from the harness) and get oil pressure up on the starter before running them up."
    So any thoughts? What should I do? I intend to drive my car to the mechanic this afternoon but I'd love some insight to what might be wrong.
    I also read that coilpacks could be the source of the problem...
  7. Re: Engine management light and misfire
    #37
    135 Post(s)
    2026 Post(s)
    This thread and your quote of my post are not relevant to a TDI. Your car will have a BMS code engine and the symptom you describe sounds like a boost control error so it is possible he has left off or incorrectly connected a boost control vacuum hose. The sensible first step would be to have a fault code read done as this will help pinpoint the reason for the "limp mode" it is going into.
  8. Re: Engine management light and misfire
    #38
    Jun 2025
    United Kingdom
    Swanny99 do you have any updates to share on your misfire problem. I have a similar problem. Did you check your ecu and found any solution?
  9. Re: Engine management light and misfire
    #39
    135 Post(s)
    2026 Post(s)
    @PoloBMD, start your own new thread, resurrecting one started 15 years ago and lst respond to 9 years ago isn't going to get much of a response.
  10. Re: Engine management light and misfire
    #40
    135 Post(s)
    2026 Post(s)
  1. Please Help engine management light keeps coming on
    By djackson 26 in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 17-01-2010, 11:11 PM
  2. 2004 Golf Mk4 1.4 Match - Misfire & Brake Switch Errors.
    By mlilburn in forum Golf MK4 - 1999 - 2004
    Last Post: 26-11-2009, 08:45 AM
  3. Please Help Engine Management Light on
    By babyjesus1985 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 07-11-2009, 12:14 AM
  4. "How To" The FAQ & How To Thread
    By Ben in forum General
  5. Light misfire and poor fuel consumption on 2.8 ACK engine
    By ajsphead in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 23-02-2008, 08:59 PM
