Thread: Corrado wipers
Results 1 to 10 of 18
  1. Question Corrado wipers
    Oct 2006
    Collier Street
    My wife's recently brought a Corrado to replace her Scirocco (Now my track car ) and the wipers are c**p. I've heard there is an easy fix with Lupo wipers, can someone confirm and let me know which wipers I need, heard something about using 2 drivers side ones or something like that.
    Robin
    Canada
    Are they slow? maybe the mech need a good clean and re-greese.
    Oct 2006
    Collier Street
    No they're not slow, they do work better on the higher speed, but I've heard about the Lupo swap and was after some confirmation. It's listed as a common problem on another forum, with the Lupo conversion as a solution. Will probably go ahead and let everyone know how it goes,
    Robin
    May 2007
    surrey / yorkshire
    yes it is a feasable swap.
    but if you are handy with a dremmel type grinder, you can grind down the stops on the hinge section of the wiper arm a little bit on your existing wipers and that really improves them. and its cheaper too. though you might want to remove them from the car before you try.
    Mar 2007
    J27 M5
    im running lump wiper conversions of my 2 corrados, so much better than the originals or the arm mod
    Things I do : Engine Swaps, Modifications, Car Audio Installs
    Things I dont do : Diesels
  6. Re: Corrado wipers
    Sep 2007
    From memory, when i owned a C. I had to buy a nearside and offside Lupo GTI wiper set and two driver arms. You have to swop the driver to passenger wiper and vice versa.
    But it is a mod which is well worth it. Unless you go the Rainex route.
  7. Re: Corrado wipers
    BlackVR6 Guest
    Done this conversion defo worth the money plus they look far better than the standard ones.
  8. Re: Corrado wipers
    Oct 2006
    Collier Street
    Has anyone done the aero wiper conversion, as I've seen these advertised for about £70 saying that they are corrado wipers that work, any confirmation on this.
  9. Re: Corrado wipers
    Hi, not sure of the kit you have seen advertised. But if you just go to you local VW dealer and ask for 2 x driver side Lupo GTi aero wiper arms and a driver and passenger set of blades they will just swap straight over. RRP for the lot is about £90 but most people find that you can haggle with them. That and a headlight loom mod are a must for the Corrado
  10. Re: Corrado wipers
    paul20v Guest
    hi
    if your still intrested i used tt arms and blades 2005 model drivers side only the passenger one requires a small bend on the blade end but easily done the difference is amazing even better than the lupo one which are great over standard the tt ones use aero2 wipers and have heavier spring and more sculptured arms it took about half an hour to do the whole job
  1. Corrado VR6
    By chrisp in forum Scirocco - Corrado
    Last Post: 10-06-2009, 08:56 AM
  2. Corrado door
    By eugmul in forum Scirocco - Corrado
    Last Post: 24-05-2007, 11:15 PM
  3. VR6 Corrado ABS problem
    By Igor_rix in forum Archive posts
    Last Post: 17-03-2006, 04:31 PM
  4. Scirocco - Corrado
    By stuart in forum Scirocco - Corrado
    Last Post: 26-04-2004, 10:58 PM
