Thread: centre console interior lights
  1. centre console interior lights
    Hi All,
    Looking for a little help, what i have noticed over the last few weeks is that when i turn on the lights the three interior rings / lights that highlight the temp , fans and direction of the fans seems to have a mind of its own. Sometimes they light up sometimes they don't.
    Not sure if this is a loose / faulty wire or if the bulbs may need changing. If any one can tell me how obtain access to the back of the interior lights panel to disconnect it would be much appreciated so i can investigate
    Matthew
  2. Re: centre console interior lights
    Aug 2008
    Hereford
    Put the fan speed on speed 2 (without the key in the ignition!!) get a pair of pliers and put some soft tissue between the noses and pull on the dial, the whole dial will come out and the bulb which lights up all 3 dials is in behind the dial... very fiddly to replace mind!!!!!
  3. Re: centre console interior lights
    Cheers thanks for the tip. I will give it a go and see how i get on
  1. Bentley announces detailed specification of new mulsanne
    Last Post: 02-03-2010, 08:11 PM
  2. Bentley announces detailed specification of new mulsanne
  3. Centre console - B5.5 into B5?
    By Alun in forum Passat - Archive Topics
    Last Post: 26-01-2008, 03:42 PM
