Thread: pinch bolt
Results 1 to 10 of 16
  1. pinch bolt
    ju1es1970 Guest
    Hi every1.
    ive just started to have a go at changing cv boot when i came to losen the pinch bolt that holds the 2 upper suspension arms and the nut has snapped off.
    Has any1 got any ideas on how to remove the pinch bolt now that the nut has broke off?
    any help would be great thanx
  2. Re: pinch bolt
    Well for a start,you do not have to loosen the upper arms,to replace the cv boot,however,there is only one way to remove the bolt now and that is heat,unfortunatley the ball joints will be destroyed,so you are looking at 2 new upper suspension arms.there is a special tool for removing the bolt,but in most cases when the bolt is seized the tool is of no use,and heat is the only alternative
  3. Re: pinch bolt
    Jul 2008
    stoke on trent
    ive always used a very big hammer and punch after soaking in penetrating oil and never had to destroy any arms, did have to remove complete hub once to get enough of a swing
    99 a4 b5 1.8tqs saloon
    99 a4 b5 2.5tdi avant
    90 eunos roadster
  4. Re: pinch bolt
    the bolt has snapped so you can imagine how hard the bolt is seized,you can hammer from now to the cows come home and you will never get that bolt out without heat
  5. Re: pinch bolt
    ju1es1970 Guest
    Think it is moving, slowly. Hehe.
  6. Re: pinch bolt
    Jul 2008
    stoke on trent
    keep hitting it
    owned 8 b5s plus bought some s4 hubs with arms attached and got every pinch bolt out eventually! sheared 3 or 4 bolts, had to remove a one assembly, and soak a few overnight though, oh and one actually came straight out
    kenny out of interest do you know which way bolt is in from factory thread towards car or wheel?
    90 eunos roadster
  7. Re: pinch bolt
    not sure what you mean [QUOTE]bolt towards car or wheel, the bolt i'am referring to is fitted first in the rear upper arm,which means the nut is to the front of the vehicle
  8. Re: pinch bolt
    ju1es1970 Guest
    i will get back to u and let u know how i get on
    cheers
  9. Re: pinch bolt
    134 Post(s)
    2009 Post(s)
    There is a way to remove the top bolt without heat, the trouble is the set costs around £500 from Klann. I do CV’s by removing the two lower joints but that can still be fun without the tools.
  10. Re: pinch bolt
    That is the tool i was referring to,but as i said previously if the bolt is really seized,the tool is'nt worth tuppence,we have given it up as a bad job,broken three of them,have a fourth one lying in a cupboard somewhere for intern quality control use only
  1. Replacing A Worn CV Boot
    By grahamcoutts in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 18-03-2011, 01:13 PM
  2. Question driveshaft boot
    By mickofcram in forum Passat - B5 Forum - 1997 -2005
    Last Post: 31-01-2010, 10:50 PM
  3. cv boot replacement, top pinch bolt
    By chrismac10 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 31-03-2009, 10:41 PM
  4. Polo brake caliper bolt seized
    By trevh in forum Polo - Derby - Lupo - Fox
    Last Post: 11-08-2007, 12:23 PM
  5. Help !! Can't get pinch bolt out of clamp
    By SteveRW in forum Passat - Archive Topics
    Last Post: 03-03-2007, 06:52 PM
