Thread: R32 lump into 2.8 V6 4 Motion?
Results 1 to 10 of 10
  1. R32 lump into 2.8 V6 4 Motion?
    Im thinking about getting a golf v6 4 motion due to my V5 being highly unreliable from day one and very underpowered .
    I drove a v6 and they look and feel beautiful to drive but im thinking about having a r32 engine put in it ,is this possible?
    Speaking mainly on the engine side because i know the r32 has bigger brakes etc.
    I know there both V6's but is the only differences the piston and bore sizes? Or is there any sensors/wiring which differs and are the manifolds, mounts and pipes the same?
    Also what engine Code should i be looking for on the r32 lump as i think i was told there are two.
    Anyone done this before?
  2. Re: R32 lump into 2.8 V6 4 Motion?
    134 Post(s)
    2015 Post(s)
    I have a saying, “never build a car you can buy”. If you want an R32, go and buy one as building one in a 4-M will ultimately cost you more than buying one.
  3. Re: R32 lump into 2.8 V6 4 Motion?
    Feb 2010
    basingstoke
    I kinda agree with crasher although it would fit but you'll prob have to change looms, ecu, almost everything i would think.
    I have the v6 4 motion and gotta say I love it !!
    might treat it to a remap and exhaust soon.
  4. Re: R32 lump into 2.8 V6 4 Motion?
    im not looking for a r32, im more than happy with a 2.8 v6, but i have found a r32 engine going cheap. So im just wondering if i tried putting it in would it fit without too much modification? obviously i will get the 4 motion ecu remapped to a r32 map.
    Like i said not after a r32 just would be nice to have a r32 engine, obviously r32 have different suspension setup, arb setup, bodykit ,interior etc.
    Just as there both v6's i thought the looms, gearbox, 4wd system, mounts would be the same .
  5. Re: R32 lump into 2.8 V6 4 Motion?
    134 Post(s)
    2015 Post(s)
    The base engine units are pretty much the same. Why is the R32 engine going cheap? They are as rare as hen’s teeth!
  6. Re: R32 lump into 2.8 V6 4 Motion?
    engines comming out of a r32 in a salvage yard thats all im going to say as i dont want to give too much info in case someone else snatches it.
    Are they that rare though?
    If the base is basically the same the loom and sensors should be very simular should'nt they?
    Also are the manifolds the same or would i need to buy the r32 ones aswell.
  7. Re: R32 lump into 2.8 V6 4 Motion?
    134 Post(s)
    2015 Post(s)
    Golf 4 2.8 and 3.2 VR6 engines (BDE, BFH and BML) are almost identical in their base unit (head and block) form.
  8. Re: R32 lump into 2.8 V6 4 Motion?
    my code is aue does that mean its not easily swapable. Whats the difference between the aue and the ones you mentioned.
  9. Re: R32 lump into 2.8 V6 4 Motion?
    134 Post(s)
    2015 Post(s)
    The AUE is much earlier, up to 2001 so there may be some differences that I have not thought of. As I have tried to say, I would not do this conversion so I cannot advise any further.
  10. Re: R32 lump into 2.8 V6 4 Motion?
    no problems im not 100% on it myself yet as i can see a few problems already just testing the water.
    I think the aue has only a single coil pack where as the post 2001 v6's have individual coil packs so there will be an issie there unless there is a r32 engine model which also has a single coil pack.
    Also the aue has only one vvt on the inlet side while i think the r32 has two one one the inlet and one on the exhaust which i may be able to get around if the 4 motion exhaust manifold fits the r32.
    Also Thanks for your help crasher
  1. Attention Audi Picture in Motion Interface
    By Incaripod in forum In Car Entertainment
    Last Post: 23-02-2010, 03:09 PM
  2. golf 2.8 v6 4 motion
    By geordiev6 in forum Golf MK4 - 1999 - 2004
    Last Post: 22-05-2008, 08:05 PM
  3. R32 Exhaust.
    By squinty in forum Golf MK4 - 1999 - 2004
    Last Post: 28-04-2008, 10:45 AM
  4. PRICING AND SPECIFICATION CONFIRMED FOR GOLF R32
    Last Post: 26-09-2005, 07:33 PM
  5. FIRST DETAILS OF NEXT GENERATION GOLF R32 ARE UNVEILED
    Last Post: 11-08-2005, 08:36 PM
