Thread: Change notification chirp on alarm setting
  1. Change notification chirp on alarm setting
    Sep 2008
    Have turned on notification chirp when locking/unlocking doors with remote, is there a code to change chirp to horn sounding, or different sound, as its a bit quiet in noisy areas?
  2. Re: Change notification chirp on alarm setting
    Sep 2009
    London
    I don't think this is possible, only way to make it sound louder is by adding a NEW, more powerful alarm speaker. You could also plug up a horn instead of the alarm speaker but won't recommend it as you don't want your car sounding silly.
    2004 golf mk5 with retrofitted: cruise control, MFSW, Highline clock diplay, angel lights.
  3. Re: Change notification chirp on alarm setting
    Sep 2008
    Cheers for the reply
    Its just a while ago I stumbled across a thread on a forum where some guy implied it could be done through coding.
    Probably cheaper to buy a hearing aid then!
  4. Re: Change notification chirp on alarm setting
    Sep 2009
    London
    If the alarm is original then it could possibly be set.
    I am about to fit an alarm that is made for golf mk5 and works off the original immobilizer, the guide states that the horn can be used instead of a siren.
  5. Re: Change notification chirp on alarm setting
    Sep 2008
    do you mean all the alerts are wired through the horn instead of the siren, ie the siren is disconnected? Or there is some info in this guide as to code notification chirp through horn instead?
  6. Re: Change notification chirp on alarm setting
    Sep 2009
    London
    There are 2 options for the alarm that i am going to fit:
    Option 1: wire the alarm to the horn instead of siren.
    Option 2: wire the alarm to siren....
    Option 1 is there because i might not currently have the siren, obviously i will be buying one.
  7. Re: Change notification chirp on alarm setting
    Sep 2008
    In byte 16 (vcds)
    Bit 4 is unticked and is "Alarm siren installed"
    bit5 is unticked and is "Siren tone Type" 0=frequencymodulated/1=intermittent
    bit7 is unticked and is "Siren alarm type" 0=10 tamper alarms/1=1 tamper alarm
    So can anyone please shed any light as to what these settings actually do and how come bit 4 is unticked?
    Many thanks
  1. Interesting information about the A4 Cabriolet Alarm
    By grahamnice in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 20-05-2009, 06:39 PM
  2. alarm triggered with driver door
    By Steve-R in forum VCDS - General Questions
    Last Post: 05-05-2008, 07:31 PM
  3. Passat TDi - ANOTHER Alarm Fault (help!)
    By EdF in forum Archive posts
    Last Post: 06-01-2008, 05:13 PM
  4. Flickering bonnet light on computer & alarm going off - 2002 TDI V6
    By CuoreSportivo in forum Passat - Archive Topics
    Last Post: 10-12-2006, 01:31 AM
  5. Central locking & Alarm Program Code
    By sanstorm999 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 27-09-2006, 04:11 PM
