Thread: A4 Avant wind noise from vents
Results 1 to 10 of 14
  1. A4 Avant wind noise from vents
    Mar 2010
    Banbury UK
    I have had this problem from new and the Audi dealer says no problems, but if you are travelling at say 80mph the air rushes through the vents at 80mph whatever fan speed you select. The only way to stop it is to select 're-circulate' or 'feet' & 'screen' together. .
    I cut myself a restrictor plate that fits neatly under the pollen filter and all has been well for 4 years. Recently Audi found it and went berserk. They told me the heater would over-heat (yeah right) and took it out.
    They said there is a new 'thicker' pollen filter that addresses the wind noise problem. I purchased one immediately (for £27.50!) but it didn't make any difference.
    I've driven a lot of vehicles and I don't know any that fresh air comes in as fast as you are driving! Its like having a hole in the front of the car!
    I would like to hear if anyone has this problem? Or conversely, does any one have an A4 Avant without this problem?
    Cheers. .
  2. Re: A4 Avant wind noise from vents
    Southern County Softy
    20 Post(s)
    can you not close the vents or turn down the amount of air coming in ?
    A4 2.5 tdi QS (mapped)
  3. Re: A4 Avant wind noise from vents
    Dec 2009
    southampton uk
    I am on my second A4 avant as is my son and he has had an S3 and we have driven several more and none have had this feature! It seems that there is something wrong in the vent system because all modern cars s/b draft proof and if you want air you demand this by using the blower.Controlling by using flaps takes me back to my 1956 ford days!I dont see why audi expect you to put up with this any longer and they must be joking to say it is normal
  4. Re: A4 Avant wind noise from vents
    Dec 2007
    I had something similar on a mk4 Golf, in A/C mode and the recirc in one of the positions......... used to turn the stereo up as it was tres annoying!
  5. Re: A4 Avant wind noise from vents
    Basically the dealer has lied to you since you bought the car.
    The vent system will restrict the flow of air through the cabin and there is something wrong with yours if this is not the case. You havent bought a 1972 Morris so there is no way a full blast of air should happen, IMO the dealer didnt want to face up to the cost of taking your interior apart to check all the vents so basically spun you a line.
    I can be doing a 100mph and I dont get blasted in the face by air, I leave mine on Auto and job done.
    I will happily stand corrected if Audi had a massive engineering blowout and designed a system so rubbish that you needed to put a restrictor plate in!!
    Perhaps best you get a 2nd opinion on your system. I hope you get it sorted.
    B7 RS4 Sprint Blue Avant with all the trimmings
  6. Re: A4 Avant wind noise from vents
    Jun 2008
    Beverley, east Yorkshire
    agreed. mine has no issues as you have described. air is controlled by the fan at whatever level is selected. stand your ground as this is not ok
    A4 AVANT 2.5TDI SPORT QUATTRO
  7. Re: A4 Avant wind noise from vents
    Mar 2010
    Banbury UK
    Many thanks for all your replies - I may have to print this thread and take it to show the dealer.
    Kite- I can close the vents but the noise is no better as it just buffets the back of the vents (and of course I get no hot/cold air)
    I've put my restrictor plate in again now and all is well - but still cant believe how Audi can thing this is normal for a 'luxury car'
    BTW I wrote to Audi in Germany about this and they just referred me back to the dealer.
  8. Re: A4 Avant wind noise from vents
    Dec 2009
    southampton uk
    I would get yourself a drive in the dealers car so that they can demonstrate that it does the same as yours which it wont do or tell them we will turn up with our cars to show them that we know that they lie and your car needs sorting pdq and compensation is due for putting up with their nonsense for so long .I think we ought to have full details posted so others are warned to avoid them
  9. Re: A4 Avant wind noise from vents
    20 Post(s)
    I would do as mickey says, get a drive in a dealer car show them that yours is wrong....
  10. Re: A4 Avant wind noise from vents
    Mar 2010
    Banbury UK
    Quote Originally Posted by kite View Post
    Thats where the difficulty lies - I've done this and taken the workshop manager for a trip. He said, yes it was a little bit noisy but it was normal. .
  1. New A4 S Line details
    By Brioss in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 02-03-2008, 06:35 PM
  2. Pricing Set For Uk-bound Audi Tts Coupe And Roadster
    Last Post: 13-02-2008, 08:03 PM
  3. A4 Avant power steeering noise
    By ColinP in forum Audi A4 - Archive Topics
    Last Post: 11-02-2007, 03:28 PM
  4. The new Audi A6 Avant
    Last Post: 20-11-2004, 09:09 PM
  5. New Audi A4 raises stakes in the compact executive class
    Last Post: 13-09-2004, 07:51 PM
