Thread: Clutch problems
  1. Clutch problems
    May 2007
    Little Houghton, Barnsley, United Kingdom, United Kingdom
    I have herd of this problem before on this forum but can not remember the solution!
    When the engine is in neutral and i depress the clutch pedel the engine judders and the revs drop to about 600rpm but soons picks itself back up.
    I have herd people saying that when they are driving, i.e changing gear to corner and the engine stalling, this is kinda the same thing but not when driving, even tho my car does get very close to stalling but just as it gets too low on revs it pick itself back up again.
    can anyone please refresh my memory on what the solution is please
    thanks.
    May 2007
    Essex
    Hi, going by the other threads on this forum, it is a very common problem with VW's. The most common solution, it seems, is to clean out the breather pipe from the engine to the airfilter. Not sure why a blocked pipe would only affect the car when the clutch pedal is depressed, but for no cost but about 10 minutes of your time it has got to be worth a try!
    Good luck
    Paul
    If it ain't broke, keep fiddling 'til it is!
  1. New clutch judders - faulty clutch fitting or fly wheel?
    By srana in forum Passat - B5 Forum - 1997 -2005
    Last Post: 22-10-2007, 09:31 AM
  2. vw vento clutch problems
    By radpm2 in forum Vento - 1994 - 1998
    Last Post: 31-05-2007, 03:38 PM
  3. burnt clutch or intercooler problems
    By Iainlaw in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 19-04-2007, 02:24 PM
  4. clutch gone
    By stubbsy in forum Audi A4 - Archive Topics
    Last Post: 27-03-2007, 05:27 PM
  5. Clutch problems??
    By MarkMk3 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 26-03-2006, 10:06 PM
