Thread: Squeak from the air vents
  1. Squeak from the air vents
    May 2007
    This has been an irritation for years.
    What is the best way to deal with this? Sometimes I blast the air and it goes. Sometimes I turn the air off.
    It sounds like a moving part (a small fan) so a bit of WD40 might help but Where should I spray it?
    May 2007
    Essex
    I tried that trick many moons ago on my old BMW. BIG MISTAKE! Could not get rid of the smell of the WD40 for months!! Best bet is to get the Haynes out and tackle the little fan inside the main center vent area. If you can get to it, a little smear of grease on the fan spindle should do the trick.
    Good Luck.
    Paul
    If it ain't broke, keep fiddling 'til it is!
  1. Creaky, rattly , heater vents on MKV golf HELP!!!!!
    By glynndood in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 01-06-2007, 07:41 PM
  2. Pedal Squeak
    By benGT in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 03-03-2007, 01:05 PM
  3. Dash air vents - How to replace bulbs?
    By Bod in forum Passat - Archive Topics
    Last Post: 12-11-2006, 10:35 AM
