Thread: cv boots
  1. cv boots
    ju1es1970 Guest
    Hi every1
    Just looking for a bit of advice on how easy or hard a cv boot is to replace as both have split and have failed on the mot.
    The cv joints are fine but just need to replace the cv boots any help would be great cheers peeps.
  2. Re: cv boots
    Jul 2008
    stoke on trent
    found this on another forum
    http://www.audifans.net/ftopict-22270.html
    no need to undo inner joint though just do it in place
    if youve never had pinch bolt off before you will probably end up destroying it getting it out so get a new one before you start and grease with coppaslip when you refit
    you also need a 14mm heavy duty hex bit and long breaker bar to undo hub bolt
    99 a4 b5 1.8tqs saloon
    99 a4 b5 2.5tdi avant
    90 eunos roadster
  3. Re: cv boots
    ju1es1970 Guest
    cheers for this,brilliant stuff. thanx alot i,ll post to let u know how i get on . cheers
  4. Re: cv boots
    ju1es1970 Guest
    Hi i was going to have a crack at the cv boot today to realise that the hub nut isent a 14mm hex bolt.
    does any1 know wat size it is,and its not a hex bolt.
    cheers any help would be great cheers.
  5. Re: cv boots
    Jul 2008
    stoke on trent
    o.e need a 14mm allen/hex key not socket to remove them
    ive seen replacements with 17mm socket heads ?
    90 eunos roadster
  6. Re: cv boots
    ju1es1970 Guest
    hi again
    it must be a replacement then as its deffo a socket head on it.but ive tryed a 23 mm on it and its still to small not bye much it aint but still to small.
  1. Question Winter boots
    By Nuggs in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 05-08-2009, 08:13 PM
  2. Question cv boots / boot spring / door fit
    By thomaswood in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 16-06-2009, 09:43 PM
  3. Fixed my CV boots, broke my ABS?
    By daveharris in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 01-09-2007, 12:54 PM
  4. CV Boots
    By bigfoot442 in forum New Member Introductions
    Last Post: 29-08-2007, 12:35 AM
  5. CV boots done - problems found
    By vwmark in forum Passat - B5 Forum - 1997 -2005
    Last Post: 30-04-2007, 10:53 AM
