Thread: Cambelt Changing
  1. Exclamation Cambelt Changing
    May 2007
    South West
    Hi there im dan and i have a vw polo 1.4CL 8 valve.
    my car has done nearly 45k and i am about to change the cambelt on it, i have a feeling the 1st major service on this car is at 60k but as the car has been stood for a while i am going to change it sooner as i would not want it to break as it could be perished or torn.
    If anyone has any ideas on what the cambelt is also driving could they please write back, i have a feeling that it maybe driving the water pump aswel but i dont want to have to take the alternator belt off then the cover to find ou what else its driving as when i do all of that im nearly there!!
    any comments on this would be much appreciated
    thanks
    Mar 2007
    Just give the VIN number to your local VAG parts dept. Should get you the correct VW approved belt
    May 2007
    South West
    Quote Originally Posted by Singlespeed View Post
    thanks that makes perfect sense, do you fink pattern parts is a good idea for the belt and new parts? i know that vw parts can be expensive.
    Mar 2007
    Theres probably only a few pounds difference between original and pattern part for the belt alone. Different matter if you start paying for labour as well.
    IMO cheap belts can be a false economy. As can saving money if you don't know exactly what your doing ( big understatement )
    May 2007
    South West
    well i am currently working in a garage as an apprentice and one of the lads i am working with said they would help me, i would want to do it with someone else as it would help me 2 learn but also get it done alot cheaper. thanks for your input i will ring my local dealer on tuesday and get a quote on all the parts needed, and i can find exactly what i will need.
    cheers
    Mar 2007
    Quote Originally Posted by saunders1587 View Post
    cheers
    Being as you work in a garage, try for trade discount as well then. Probably worth trying your garage parts supplier as well then and ask for the OE fit parts instead of the cheapest pattern crap.
    I'm not saying that pattern parts are always crap, but once bitten by a belt snapping at 18K. Top end rebuilds cost a lot more than the relatively small ( if any ) saving on the belt/idler.
  1. changing bulbs
    By jack71 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 06-06-2007, 02:36 PM
  2. Changing A3 sidelights???
    By matt4spurs in forum Audi A3 - Archive Topics
    Last Post: 16-05-2007, 09:27 AM
  3. Changing Engines
    By Turkster in forum Passat - Archive Topics
    Last Post: 30-01-2007, 02:35 PM
  4. Changing language
    By aidanjaye in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 13-01-2007, 08:20 PM
  5. Changing Battery on 1.8t
    By Janusian in forum Passat - Archive Topics
    Last Post: 24-12-2006, 10:17 AM
