Thread: Engine Managment Light!!!!!
Results 11 to 20 of 31
  1. Re: Engine Managment Light!!!!!
    DSG4ME Guest
    Disconnect the battery overnight, it may just clear itself, brace yourself for a big bill though, the thing you describe is the same as the steering shaft ecu unit failure, and it's about £1000 to fix.
  2. Re: Engine Managment Light!!!!!
    Mar 2010
    Glasgow
    I Have just had the codes read.......the following has come up -
    (J271) or (J363)
    P1517/007 short to ground.
    All faults are clear and the guy recons its a fuse somewhere, the hand book isn't too clear...can anyone shed ant light????
    Thanks for info to date guys.....
  3. Re: Engine Managment Light!!!!!
    Mar 2010
    Glasgow
    further searches on google point to Power supply relay for ECU??? where abouts is this relay fitted? if the info is correct, can i replace it?
  4. Re: Engine Managment Light!!!!!
    131 Post(s)
    1974 Post(s)
    17925 (P1517) Motronic Engine Control Module (ECM) Power Supply Relay - J271 Electrical malfunction in circuit.
    I need your cars engine code, is it BKP?
    Does the cooling fan start to run after a few seconds if the ignition is left on?
    I have had this fault before when the relay on the electronics box next to the battery fails or the command power supply to the relay fails due to the tiny 0.35-mm wire from the ECU snapping but this causes the cooling fan to run.
    I can’t check from home but I think that is the code we get when an injector fails.
    You can eliminate it being the relay by unplugging the J271 relay (it has 458 printed on top, in between fuses 8 and 9) and bridging out the terminals on the plate that correspond to the two large terminals on the relay (30 and 87) on the plate (sockets 1 and 2).
  5. Re: Engine Managment Light!!!!!
    Mar 2010
    Glasgow
    Hi Crasher,
    the only relay fitted in the fuse box beside the battery is marked - 064021B
    I left the ingnition on for a couple of minutes and the fan didn't come.
    Shall i remove the relay and short-out the terminals as suggested?
    Engine number is BKP 183735
  6. Re: Engine Managment Light!!!!!
    Norfolk
    I wonder if it is an electrical fault due to a failed antishudder valve. When this fails shut, you can't start the engine. If you take the air intake pipe off to the egr valve you will see if the antishudder plate is open when the ignition is turned on. If it isn't, just wedge it open and see if it starts. I only say this because failed antishudder valves sometimes throw up silly electrical fault codes.
  7. Re: Engine Managment Light!!!!!
    #17
    Mar 2010
    Glasgow
    I have done a few searches of the forum and their seems to be prolems with the Seimens fuel pump, could this be related in any way? or do the fault codes rule the pump out?
  8. Re: Engine Managment Light!!!!!
    #18
    Norfolk
    I think it will turn out to be an injector as Crasher says. The "17925 (P1517) Motronic Engine Control Module (ECM) Power Supply Relay - J271 Electrical malfunction in circuit" code is misleading because it only applies to petrol engines. I think the code reader finds the nearest code to match the fault. There are a number of electrical/fuel system faults that give odd codes like this.
  9. Re: Engine Managment Light!!!!!
    #19
    131 Post(s)
    1974 Post(s)
    Guided Fault Finding lists 17925 under mot6000 but only versions 000, 001, 002 and 003 not 007 so I think the code reader has mis-interpreted the code. I think you need to get the car recovered to a garage who can check the codes properly and go from there. I will try and look into the code we had from the last one of these we did a few weeks back.
  10. Re: Engine Managment Light!!!!!
    #20
    Mar 2010
    Glasgow
    Thanks again for the advice to date, i will try and get the car recovered tomorrow to VW dealers/specialist
  1. HID Aftermarket kits - Not Legal....
    By RickT in forum Chat - Anything with wheels
    Last Post: 13-05-2011, 12:44 PM
  2. Lamborghini gallardo lp 570-4 superleggera
    Last Post: 02-03-2010, 08:17 PM
  3. Please Help engine lumpy/hesitant when cold esp light coming on.
    By Mark Redman in forum Golf MK4 - 1999 - 2004
    Last Post: 22-09-2009, 10:41 AM
  4. Please Help Battery + Climate Control Unit + Engine + What's next?
    By bartyboy in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 02-05-2009, 07:39 PM
  5. A4 engine management light .help
    By piggyA4 in forum Audi A4 - Archive Topics
    Last Post: 28-11-2007, 12:25 AM
