Thread: VW Golf engine seized - Cat D
  1. Question VW Golf engine seized - Cat D
    Jul 2008
    How is it possible for a 'low level flood' to cause a car engine to seize up?
    The insurers have classed the car as CAT D only because of the engine is seized.
    Would it, or is it possible to repair this engine in this condition?
    What is the work & cost involved etc?
    Alternatively how much would it be for a brand new engine?
    What alternative VW engines could replace this one?
    Its a 2002 VW Golf 1.9 SDI - had covered 70k miles.
    At present the insurers have put a price on the car as it stands if i want it back @ £2000 - is it worth the hassle?
    Any advice or tips / help would be grateful.
  2. Re: VW Golf engine seized - Cat D
    Southampton, UK.
    Once a significant amount of water gets in through the air intake, the pistons try to compress the incompressible, which results in bent conrods and all. On AutoTrader, you can pick up a 2002 Golf SDI from around £2,750 to £3,000. Rebuilding an engine isn't cheap, £2k maybe, so that's why it's being written off. Personally, if I really wanted to keep the car, I'd try to find an engine from a scrappie and take my chances. Other than that, take the money, but a £2k valuation sounds a bit on the low side.
    2003 VW Golf Est 1.9 TDI 130
    2006 Audi A3 2.0 TDI Sport 140
  3. Re: VW Golf engine seized - Cat D
    Feb 2010
    basingstoke
    depends on how fast the rpm at the time I have got away with it a few times for customers by just draining out the bores and intrcoolers good as gold if there is def something bent unless u love it. I wouldn't bother
  4. Re: VW Golf engine seized - Cat D
    Nov 2008
    folkestone.kent
    how did the water get into the intake,its a long way above a shallow water line ,the air cleaner is more or less level with the headlights !!
  5. Re: VW Golf engine seized - Cat D
    SHEFFIELD
    Quote Originally Posted by VAGMAN54 View Post
    We had loads at work a while back with moosive puddles/lakes across the road which cars were getting through ok until another vehicle came the other way sending big waves back across the road,but i wouldnt bother without sounding horrible,to have the engine stripped down and checked for damage can be costly unless you can do yourself and getting a good engine from a scrapper itself is russian roulette
    I dont work here for the pay,or the enjoyment,so why do i work here
  1. What no more Longlife 2 oil ??
    By kimsue in forum Touran - Sharan - Caravelle
    Last Post: 12-08-2010, 04:40 PM
  2. Replies: 0
    Last Post: 15-08-2009, 07:48 PM
  3. More economical, more practical: The new golf plus bluemotion:
  4. New Golf Estate Set To Break Cover At Geneva Motor Show
    Last Post: 27-02-2007, 09:15 PM
