Thread: Metalic sound from around aux belt
Results 1 to 10 of 17
  1. Metalic sound from around aux belt
    Jul 2009
    nottingham
    I'm after a bit of advice I have a 2003 A4 avant 130 tdi. When at tick over you can hear a slight metallic noise from around the aux belt area it sounds a bit like a chirping noise. When you rev the noise goes away I Have taken the tension of the belt and I can turn alternator and tension pully ok.
    Last year I had cam belt water pump and cam belt tensioner replaced so it shouldn't be from there
    any advice or simular problems please
    Thanks MFTM
  2. Re: Metalic sound from around aux belt
    Dec 2009
    southampton uk
    Could be a pulley failing or cracked and it may be best to have a close look before it gives up and causes damage .I think its advisable to change all the belts and have pulleys checked when the cam belt is done.Whats the mileage?
  3. Re: Metalic sound from around aux belt
    Jul 2009
    nottingham
    Only 72000. do you know if they are clutch bearing pullys
  4. Re: Metalic sound from around aux belt
    Mar 2009
    As far as I know the only one that has a clutch in the pulley is the alternator one.
  5. Re: Metalic sound from around aux belt
    Jul 2009
    nottingham
    should all alternator pulleys on audi be one directional as i can turn mine both ways ?
  6. Re: Metalic sound from around aux belt
    sounds like you have a dry or rough bearing on one of your front pulleys, can often be difficult to track down. could also be the belt slipping, that can sometimes chirp. Try silicone spray on the belt (if this cures it then get a new belt fitted and check the tensioner is not seized)
    if the silicone spray had no effect, then as mentioned previously more than likely a pulley, take your pick at which one. Best way to check is take belt off and spin them but you cant allways tell, sometimes a stethoscope or the old screwdriver to ear trick can help (with the engine running)
    hope this helps
  7. Re: Metalic sound from around aux belt
    Mar 2010
    Banbury UK
    I had this on mine and thought it was the water pump (which I had changed with the cam belt) - Turned out to be the air con crompressor clutch, which comes as a complete unit with compressor. £3k later and we're sorted!
  8. Re: Metalic sound from around aux belt
    Dec 2007
    Probably the alternator clutch pulley, common fault, £100 at a garage to fix.
  9. Re: Metalic sound from around aux belt
    Mar 2010
    Banbury UK
    The alternator has a clutch? What for?
  10. Re: Metalic sound from around aux belt
    Dec 2007
    I believe its part of the pulley mechanism... I presume so it can only rotate one way but not sure 100%.
    There's alot of info about this on here, I have the same problem but I don't know of any effects if it is not replaced... just sounds awful at low revs! Although not have the a/c in econ mode does help!!
  1. vibrating noise & belt slip on full lock- serpentine belt tensioner?
    By VtecJunkie in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 25-12-2009, 04:39 PM
  2. Guide S4/A4 V6 Cambelt
    By spellmaster in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 05-10-2009, 05:23 PM
  3. TDI150 Strange sound from ancillary drive belt tensioner?
    By BoraTDI in forum Bora - 1998 - 2005
    Last Post: 21-04-2008, 01:01 PM
  4. A4 Quattro Servicing Tasks
    By MrBeardy in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 08-08-2007, 04:57 PM
  5. Aux. belt and alternator pulley change/queries
    By dvhttn in forum Passat - Archive Topics
    Last Post: 22-03-2007, 08:29 PM
