Thread: A4 170 DPF Removal
Results 1 to 9 of 9
  1. A4 170 DPF Removal
    Oct 2009
    oswestry u.k.
    Have finally found a tuner to remap dpf out of my 56 plate a4 170.
    I removed the dpf myself as wasnt willing to pay £1000 to a few companies for doing the job. Dave at Rapid Remaps of Cannock did a Remap and dpf delete. I now own a totally different car.
    8 - 10 MPG Better,
    So much more torque,
    Alot smoother all round.
  2. Re: A4 170 DPF Removal
    Jul 2008
    Stafford
    D'you mind telling us why you wanted the DPF off? I have done similar as it was end of life and made the car run dog rough half the time. Did you make a new downpipe or just cut open the original?
  3. Re: A4 170 DPF Removal
    Mansfield, UK
    How long did it take you to find a tuner? We do DPF-off even for the CR engines.
  4. Re: A4 170 DPF Removal
    Jul 2009
    Warwickshire
    Does anyone know if there are any legal issues in removing the DPF?
  5. Re: A4 170 DPF Removal
    May 2008
    10mpg increase? That cant be right surely?
  6. Re: A4 170 DPF Removal
    Oct 2009
    oswestry u.k.
    I phoned various companies out of performance vw magazine, some said they could do dpf removal remap if i took out guts out of dpf. Two well known companies would only do it if i had them cut up old dpf and refit it (for a hefty fee). I am a welder fabricator so i knew it would not be a problem to do and my mate owns a garage.
  7. Re: A4 170 DPF Removal
    May 2009
    stoke on trent
    Quote Originally Posted by m7rcu View Post
    8 - 10 MPG Better,
    Did you smash out the insides on the dpf or did you make a new pipe, if you did a new pipe would you make another and maybe sell it
  8. Re: A4 170 DPF Removal
    Oct 2009
    oswestry u.k.
    Please do not bother with Rapid Remaps it didnt work after a month and when he took map out he wouldnt refund. I took the dpf off the car at a mates garage and cut hole in it, smashed the insides out, rewelded and re fitted. Give Ben a ring from MAS Performance on 07834 879320, he makes a replacment pipe and maps out the dpf it is better than the map I previously had in. He has his garage at skipton but if you do it yourself he will meet you halfway.
  9. Re: A4 170 DPF Removal
    May 2009
    stoke on trent
    Spoke to this chap and he won't just supply the pipe. I can easily fit a removal pipe my self and get it mapped my self as well so just need the pipe. Did you have a new pipe or do you still run the dpf housing with the platinum honeycomb removed. What sort of power did you get. I know of a golf with 235. What's it done to your fuel economy, it's suppose to improve it by 10% I'd this true.
  1. A4 TDI SE 170 - Advice
    By craiby in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 30-03-2008, 09:01 PM
  2. New A4 S Line details
    By Brioss in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 02-03-2008, 06:35 PM
  3. Pricing Set For Uk-bound Audi Tts Coupe And Roadster
    Last Post: 13-02-2008, 08:03 PM
  4. Audi A4 2.0 TDI 170 S-Line Steering and Handling issues
    By DRA4 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 21-01-2008, 11:32 PM
  5. New Audi A4 Cabriolet 2.0 TDI Ticks all the Boxes
    Last Post: 09-10-2005, 12:37 PM
