Thread: caddy glow plug/brake light problem
  1. caddy glow plug/brake light problem
    Sep 2007
    Hi lads,
    Got a bit of a problem with 2005 caddy. It started with glow plug light flashing and bit hard to start. My local vw dealer informed me that the most likely cause was a glow plug control unit with no. 461 on top
    Another (maybe unrelated) problem has since developed that my brake lights won't switch off. I replaced front and rear pads and noticed the lights staying on the next day. Cant seem to link replacing pads with faulty brake light switch but could there be a link?
    I replaced brake light switch according to these guidelines
    id=1158315"]http://forums.vwvortex.com/zerothread?id=1158315[/URL]
    Now no brake light at all:mad
    The switch felt like it clicked home and I don't think that was fitted incorrectly and I don't really want to take it back out. There is power going to the switch.
    The only thing that we did when changing pads and checking glow plugs was to disconnect a relay on top of fuse board (458) in engine bay, this stopped the relay light flashing but ESP light came. We then plugged it back in.
    We ordered a new on of these from vw to arrive tomorrow along with glow plug control unit.
    Any help greatly appreciated,
    Brian (newbie)
  2. Re: caddy glow plug/brake light problem
    Feb 2011
    london, england
    hi bruwalsh
    sorry to bother you , i know this is quite an old thread but i'm having the same [flashing glow plug light on dash and brake lights on constantly] symptoms with my 05 caddy van, did you find out what the problem was and how did you solve it? also do you happen to know where the glow plug relay is? any help would be greatly appreciated. dave.
  3. Re: caddy glow plug/brake light problem
    Southern County Softy
    20 Post(s)
    Quote Originally Posted by audivanman View Post
    hi bruwalsh
    Check your brake lights are working.
    A4 2.5 tdi QS (mapped)
  4. Re: caddy glow plug/brake light problem
    Feb 2011
    london, england
    hi kite
    thanx for the response, like i said thebrake lights are on from the moment i turn the key, the pedal up or down dos'nt affect a thing and the glow plug light flashing?? this is my first caddy are there any workshop manuals that relate to this vehicle? i'd also like to check/change the relay but don't have a clue where it is.regards d.
  5. Re: caddy glow plug/brake light problem
    Feb 2011
    london, england
    hi again
    changed the brake switch and sorted the back brake lights, still got the flashing glow plug light on the dash , changed the glow plugs and the glow plug wiring harness and still got the flashing light ,anyone help on fuse/relay location.regards d.
  6. Re: caddy glow plug/brake light problem
    20 Post(s)
    the flashing glowplug light may be indicating a stored fault code.
    try disconnecting the car battery for 10 mins. or have a fault scan.
  7. Talking Re: caddy glow plug/brake light problem
    Feb 2011
    london, england
    hi kite
    issue now resolved, changed the brake pedal/switch, part no;S1k2945511rdw, bit tricky to locate and turn untill it clicks! happy days. still can't work-out why they would link that to the g/p light, but anyway done, so thanks again for your time. d.
  1. HID Aftermarket kits - Not Legal....
    By RickT in forum Chat - Anything with wheels
    Last Post: 13-05-2011, 12:44 PM
  2. Rear fog light / reverse light fault (golf 5)
    By 85turbo in forum VCDS - General Questions
    Last Post: 03-09-2010, 11:30 PM
  3. Volkswagen Unveils The New Caddy Maxi
    Last Post: 29-10-2007, 08:45 PM
  4. Audi A4 Brake light problem
    By agriffiths in forum Archive posts
    Last Post: 22-12-2006, 02:10 PM
  5. golf engine management light problem
    By HUTCH in forum Chat - Completely Off Topic
    Last Post: 07-11-2006, 07:04 PM
