Thread: Mass Air Flow sensor help?
  1. Mass Air Flow sensor help?
    Sep 2008
    Kildare,Ireland
    Hi all.Im lookin for some advice and maybe save myself some serious cash in the meantime.My cars revs are unstable,cuts out from low revs the odd time.When on the move shes perfect.I think it could be the MAF because when i unplug the sensor she turns over perfect,plug the sensor back in and the revs are unstable again.Anyone confirm if i need a new MAF.I could pick 1 up in a scrapyard and fit it myself for €30..If anyone knows the guys on here do...
  2. Re: Mass Air Flow sensor help?
    135 Post(s)
    2026 Post(s)
    Is it an R32? If not, what is it?
  3. Re: Mass Air Flow sensor help?
    Sep 2008
    Kildare,Ireland
    Quote Originally Posted by crasher View Post
    is it an r32? If not, what is it?
    1.6 sr m8..
  4. Re: Mass Air Flow sensor help?
    135 Post(s)
    2026 Post(s)
    An AKL engine then. Remove and clean the throttle body. After re-fitting, take it to a garage that has a diagnostic computer. They will need to check the memory for errors (a faulty Air Mass meter will be stored as you disconnected it) and then clear all codes. Then they should go into Adaptation 10, Group 00, read and save, then exit Adaptation and enter Basic Settings 04, Main Group 098, and click Go and then wait 15 seconds whilst the TB adapts. Then exit Basic Settings and Engine 01, turn off and wait 15 seconds. Then start the engine and it should settle out to a good idle which will improve over a few days.
  5. Re: Mass Air Flow sensor help?
    Sep 2008
    Kildare,Ireland
    Crasher you the man..Thnx alot.I have vag-com 309.1,could i reset myself with this??
  6. Re: Mass Air Flow sensor help?
    135 Post(s)
    2026 Post(s)
    It is a long time since I used 309 (I still have a serial cable somewhere but I have lost the licence) but I think so, there is only one way to find out…
  1. Please Help Audi A4 Mass Air Flow Meter
    By iyole in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 09-07-2009, 03:25 PM
  2. "How To" The FAQ & How To Thread
    By Ben in forum General
  3. Numerous Details on Digital Air Con Display
    By sooty in forum Chat - Anything with wheels
    Last Post: 21-01-2008, 08:09 AM
  4. Re VW Golf Air Flow Mass Meter
    By hiol in forum Golf MK4 - 1999 - 2004
    Last Post: 12-12-2007, 06:35 PM
  5. Passt 1.8T 1999 - Air Mass Sensor gone Missing ?
    By headache56 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 19-09-2007, 01:46 PM
