Thread: Help, Indicators not working..
Results 1 to 8 of 8
  1. Unhappy Help, Indicators not working..
    May 2007
    Eastwood, Essex
    98 Golf cabriolet, The indicators are not working and when i switch the Hazard lights on the switch stays permanently lighted. Ive checked the fuses and they are ok. High beam works fine. Anyone help with this please.
    May 2007
    Raunds
    could need a change of indicators, on my vectra even tho it told me when a light goes out, of the light needs replacing then it wont come on and hazards stick.
    May 2007
    hi there had thesame problem with one of my bikes and found out it was a dodgy bulb and a poor earth
    Coventry
    Sounds like it could be a faulty relay. The relay controls all flashing whether it be left, right or hazards, this would include the hazard switch its self.
    Sorry to state the obvious but do check all bulbs and fuses. It may be a dry joint somwhere but my money would be on the relay. Appraently they are just a push pull type of fitment.
    I hope this helps.
    May 2007
    Eastwood, Essex
    Also realised that the warning buzzer is not working if the lights are left on on exit of car. Where are the relays situated? Are these the ones above the fuses?. Anyone know from a manual?. Ta all.
    May 2007
    17 Post(s)
    Yeah, the flasher unit should be on the relay board above the fuses. The flasher unit will normally only have 3 terminals, so it shouldn't be too difficult to figure out which one it is. The terminals are usually marked 31, 49 & 49a (look at the base of the relay). To check if the relay is faulty, get a bit of wire (paper clip) and stick it in the holes on the relay board where the 49 and 49a go. Now put the ignition on and try switching your indicators on. The outside indicators should come on. If they do, then there is a very good chance the relay is faulty.
    Regards - Jim
    May 2007
    Eastwood, Essex
    Quote Originally Posted by Flash2 View Post
    Regards - Jim
    Jim youre a star mate, I found the relay as you discribed and discovered that the guy who wired the alarm in recently pulled some wires tight across the relay and unseated it from the board, thus a short. I pulled it out and reseated it and alls good again. Im not sure why the buzzer for the lights isn't working tho. Thanks again for your time.
    Regards, Gary.
    May 2007
    17 Post(s)
    Glad I could help Gary. Just a thought on the lights buzzer, does the interior light come on when you open the drivers door. Perhaps the alarm guy connected the alarm to the door switch and didn't put the wire back on right.
    Jim
  1. Trouble with Indicators
    By donnytella in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 02-06-2007, 12:17 PM
  2. Indicators not working, help.
    By Wessa in forum Archive posts
    Last Post: 26-05-2007, 11:53 AM
  3. Clear Indicators
    By Coupe16v in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 06-05-2007, 12:24 AM
  4. indicators have packed up !!!
    By yogise in forum Passat - B5 Forum - 1997 -2005
    Last Post: 19-04-2007, 09:01 AM
  5. A4 dodgy indicators!
    By jjt5 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 07-12-2006, 01:57 PM
