Thread: fault code p0234 loss of power
Page 3 of 3 FirstFirst 123
Results 21 to 24 of 24
  1. Re: fault code p0234 loss of power
    #21
    Jan 2012
    Rustington, West Sussex UK
    10 Post(s)
    88 Post(s)
    Quote Originally Posted by LiamP1985 View Post
    Where is this N75 sensor on a B6 as I’d like to replace mine for peace of mind.
    My local garage used an aerosol turbo cleaner which helped for a short period of time, I’m guessing it will need a few treatments though. Where are these treatments sprayed in?
    Which engine? BMR will be on the bulkhead slightly to the right of the small rack of sensor plugs above the gearbox. Other engine codes may have the N75 in a slightly different position.
    Mad Mitch
  2. Re: fault code p0234 loss of power
    #22
    Apr 2014
    SW London / Surrey
    10 Post(s)
    169 Post(s)
    Some are sprayed into the air intake to survive the trip through the engine and do a bit of cleaning as they pass through the turbo on way to exhaust. Others (oven cleaner types) are put into a non-running (but maybe warm) turbo via its EGR port or exhaust outlet.
  3. Re: fault code p0234 loss of power
    #23
    Jan 2012
    10 Post(s)
    88 Post(s)
    Quote Originally Posted by VAG-Abound View Post
    Most are temporary solutions to a cleaning problem. This thread is relevant for a vacuum leak in a vacuum solenoid or Turbo vacuum actuator and therefore spraying cleaner would not affect the outcome of this fault. Using cleaning sprays for cases where the variable vane system in the exhaust side of the turbo drags or seizes will only free the mechanism for a short amount of time. The proper solution is to dismantle the exhaust side of the turbo, clean it thoroughly with solvent cleaners and a range of mildly abrasive pads / cleaning materials, then grease up the contact parts of the VNT mechanism. Once reassembled you should expect at least 80 to 100k more service life if the engine is well maintained and no other issues occur that might affect turbo life e.g. oil starvation etc.
    Mad Mitch
  4. Re: fault code p0234 loss of power
    #24
    Sep 2015
    Leics
    11 Post(s)
    Soz, forgot to say it’s a BKP.
  1. Problem with Advanced Key & One-Touch Memory
    By NeilA8 in forum A8 - S8 - V8
    Last Post: 29-11-2013, 09:51 AM
  2. Esp malfunction/parking brake
    By BIGSSS in forum VCDS - Help Requests
    Last Post: 21-01-2010, 01:52 PM
  3. power loss etc gti 8v, confused!
    By johnny80 in forum Golf MK3 - 1993 - 1999
    Last Post: 20-03-2008, 02:32 PM
  4. TDI Sudden Power Loss! Later higher MPG?
    By TDI-3 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 04-03-2008, 05:32 PM
  5. P0411 fault code??
    By colina3 in forum Audi A3 - Archive Topics
    Last Post: 18-02-2008, 01:29 PM
