Thread: 1.9 TDI ended in 1998 ???
  1. 1.9 TDI ended in 1998 ???
    Jan 2010
    Berwick UK
    Having decided to go for a solid flywheel conversion instead of a replacement DMF, I looked at the site of a well known manufacturer of the solid conversions. They don't list one for my car - a 2001 Passat 1.9 TDi. They only have a 1.8 listed.
    In answer to an email, they replied that the 1.9 engine ended in 1998 and that 98 - 05 Passats are 1.8
    This conflicts with the info I have for my car (shown below)
    Which is correct?
    If they are wrong, I'm not sure I want to buy a flywheel from them - so any suggestions for a solid flywheel conversion?
    VW Passat TDI PD estate
    Year 2001
    Reg xxx
    Sales Model 3B6 262 Passat Var. Trend
    Engine AVF
    Gear FRK
    Vehicle Number WVWZZZ3B Z 2Exxxxxx
    from Engine Plate:Typ 3BG 0.90 1 AVF 1898 3020606
    Engine Size 1896 cc)
  2. Re: 1.9 TDI ended in 1998 ???
    Jan 2008
    Mansfield, UK
    They are wrong, you do have the 1.9 TDI engine.
  3. Re: 1.9 TDI ended in 1998 ???
    Mar 2009
    They are wrong, you have a 1.9TDI as already stated.
    I wouldn't bother dealing with them if they can't get the information right, there are plenty of reputable suppliers who will get the correct parts.
    I came in to this world with nothing and I've still got most of it left.
  4. Re: 1.9 TDI ended in 1998 ???
    Jun 2007
    Gwent
    As I understand it, the 1Z engine in the Audi 80 tdi has a conventional flywheel, The 90 hp AHU engine in the early B5 passat/A4 may also be conventional, or may be DMF? - I've heard both arguments...
    It's quite likely parts from an Audi 80/90/coupe petrol may be suitable? e.g 2.3 20v uses a 240mm friction plate which would probably be man enough for the job..
    2001 Passat Sport tdi 130hp
    1990 Audi coupe 20v x 2
  5. Re: 1.9 TDI ended in 1998 ???
    Norfolk
    A solif flywheel conversion kit has been available for the B5 tdi for years. I think eurocar spares do one.
  6. Re: 1.9 TDI ended in 1998 ???
    Jan 2010
    Berwick UK
    I see Eurocarparts have two listed on their site. Strangely enough they are both "Valeo" - and it is Valeo who have just told me there is no such thing as a 2001 1.9 Passat.
    Thanks martin1810 - and thanks for the other replies too.
  1. T4 1.9 tdi engine
    By CherryB in forum The Commercial Range
    Last Post: 09-04-2008, 10:38 PM
  2. 1.9 TDI pd 130 OR 2.0 TDI 140
    By FLIPKEY in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 13-03-2008, 01:25 AM
  3. A6 2.5 TDI Pierburg Maf????
    By FuNkYcHiCkEn in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 25-05-2007, 05:57 PM
  4. Replies: 0
    Last Post: 20-07-2006, 09:08 PM
  5. Audi takes pole position in TDI diesel development
    Last Post: 01-04-2006, 07:34 PM
