Thread: Missfiring 2.0 ALT
  1. Missfiring 2.0 ALT
    Ayrshire, Scotland
    18 Post(s)
    Our 2001 2.0 ALT engine recently was giving a slight cough under load, i changed all the spark plugs but it still had this slight cough under load. today the car misfired badly and threw up codes:
    2 Faults Found:
    16684 - Random/Multiple Cylinder Misfire Detected
    P0300 - 001 - Upper Limit Exceeded
    16685 - Cylinder 1: Misfire Detected
    P0301 - 001 - Upper Limit Exceeded
    So i believe i will be looking at replacing the coil pack and was planning to swap it to a different cylinder to prove there is a faulty one, but (basic question coming up) which is cylinder 1? Closest to cambelt or at the rear of engine bay??
    how much does a coil pack generally cost?
    any advice greatly appreciated
    Andy
    2001 Audi A4 Saloon 2.0
    2000 Audi Allroad 2.5TDI V6 quattro
    Fully licenced Ross-Tech VCDS Interface
    Air Suspension Compressor Repair Kits: www.bagpipingandy.com
  2. Re: Missfiring 2.0 ALT
    Mar 2010
    notts u.k
    its cambelt end
  3. Re: Missfiring 2.0 ALT
    Ayrshire, Scotland
    18 Post(s)
    Quote Originally Posted by matta4 View Post
    its cambelt end
    Many thanks, i found out with some trial and error, turns out a defective coil pack as thought,
    thanks for the reply
    Andy
  4. Re: Missfiring 2.0 ALT
    Mar 2010
    notts u.k
    should cost about £30 ish each dont fit non genuine as can be more trouble than its worth if we get a car in down on one we usually advise change all coil packs and plugs then they dont have to be touched again till next plug change as usually when one goes another is just waiting to expire not sure why they do but they seem to
  1. Please Help Best Golf for £10k and confusion over different engines?
    By deshg in forum Golf MK5 - 2004 - 2009
    Last Post: 21-09-2010, 07:47 PM
  2. Trim Confusion
    By ocelot0411 in forum Golf MK5 - 2004 - 2009
    Last Post: 15-08-2009, 11:16 AM
  3. Please can someone help
    By Daz9048 in forum Golf MK5 - 2004 - 2009
    Last Post: 05-07-2009, 08:34 AM
  4. Some advice please needed on wheel offsets - ET37 vs ET35
    By Staz in forum Passat - B5 Forum - 1997 -2005
    Last Post: 14-12-2007, 05:48 PM
  5. ADVANCED NEW FOUR-CYLINDER PIEZO TDI ENGINE
    Last Post: 17-05-2006, 08:14 PM
