Thread: Thud when releasing clutch pedal
Results 1 to 10 of 12
  1. Thud when releasing clutch pedal
    Jul 2006
    Hi all, I have searched for this, but no joy - so apologies if this has been covered before.
    I have a 2003 A4 1.9TDi with 80K on the clock. When I am in traffic & working the clutch pedal quite a bit, I notice a thud when I let the clutch pedal out (sounds as if it's coming from the back of the car). Is this a fairly common thing, and is it easy to rectify.
    Cheers,
    Mark
    Dec 2006
    is the car front wheel drive or Quatrro...??
    i guess Q... rear diff ..
    RicKT
    Jul 2006
    It's a bog standard front WD car.
    Mark
    Dec 2006
    urm.....
    Does it only do this when you release the clutch after the hand brake has been apllied??
    RicKT
    Jul 2006
    No, It seems worst when I am sitting in traffic with the pedal down for more than 5 - 10 seconds.
    Dec 2006
    sounds like the release bearing then..
    not sure why it would sound to be coming from thr rear.. unless the knock vibration travels down the car..
    RicKT
  7. Re: Thud when releasing clutch pedal
    Mauritius
    I have the same problem with my A4 TDI 2001. I hear it specially when you accelerate and brake at slow speed in traffic. The previous owner told me this is the diesel in your tank which may be half full. I had it for more than a year.
  8. Re: Thud when releasing clutch pedal
    Dec 2006
    I would says it maybe a sticky brake pad? piston?
    OR it could be a losse engine mount which is transfering the noise down the car??
    Or a lose exhaust "bung" which is flexing as the engine flexes when the clutch released..
    Its hard to guess when its a noise!
    Rick
  9. Re: Thud when releasing clutch pedal
    Sep 2007
    mine does it too. Now idea why. Ive looked and looked for a reason!! Cant be brake cos it does it when you dont use the brakes!
  10. Re: Thud when releasing clutch pedal
    Ribble Valley
    Same here mine 2. its probabley just a normal thing. My bmw 330 does the exact same thing with the same sound.
  1. High Clutch Pedal
    By Jabez in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 09-06-2010, 03:26 AM
  2. Vibrating clutch pedal on TDi Golf - any advice?
    By arthur picton in forum Golf MK4 - 1999 - 2004
    Last Post: 14-04-2009, 02:58 PM
  3. clutch pedal
    By frank99jc in forum Passat - B5 Forum - 1997 -2005
    Last Post: 25-07-2008, 09:47 AM
  4. Vibrating Clutch Pedal
    By JasonC in forum Passat - Archive Topics
    Last Post: 22-01-2007, 01:40 AM
  5. Sticking Clutch Pedal
    By Sesame in forum Passat - Archive Topics
    Last Post: 31-05-2006, 11:39 PM
