Thread: juddering ,loss of power
Results 1 to 10 of 11
  1. juddering ,loss of power
    Mar 2010
    stafford
    hi i have a 2.0 tdi passat which is a a bkp engine ,which has been plugged into about 5 vag machines now ,and no faults whatsoever ,i have had wiring harness changed and all the seals on injectors changed ,but no diffence at all ,the engine judders upto about 3rpm and then smooths out ,but seems to drag getting up the rev range ,there is no engine lights on ,ps anyone help im at the end with this car now
  2. Re: juddering ,loss of power
    I have the same problem, judder at 2,8k rpm and gone by 3,4k rpm. The problem was much worse over winter. Now the weather has warmed up its not as bad.
    Still feels down on power over 3k rpm. I'm wondering if its the MAF sensor, EGR valve or an injector on the way out.
    Its been doing it for the last five months, so I'm going to live with it unless a warning lights comes on.
  3. Re: juddering ,loss of power
    Norfolk
    It doesn't matter how many vag code reads you have if the tech only looks for fault codes. They need to look at the actual performance of the sensors and outputs. Good chance one of the injectors is not working correctly.
  4. Re: juddering ,loss of power
    DSG4ME Guest
    I'd start with a fuel temp sensor myself, £15ish @gsf, and a good quality injector cleaner in half a tank with some enthusiastic foot action, new air filter and check the hoses that connect to it for leaks, assuming the airbox has hoses going to it, these can cut the turbo out if disconnected, after that I can't quite think what to suggest other than as mentioned a MAF and possibly a coolant temp sensor.
  5. Re: juddering ,loss of power
    I'm now thinking tandem pump?
  6. Re: juddering ,loss of power
    Mar 2010
    stafford
    it is now repaired ,new seals on injectors replaced the injector bolts ,and hey presto the car works perfect no juddering or loss of power ,the mechanic said the bolts had stretched and was not clamping the injector tight ,
  7. Re: juddering ,loss of power
    Nov 2008
    Lincoln, UK
    What sort of naff bolts have they been speccing then? "If only everything was as reliable as a Volkswagen" It wasn't like this in air cooled days!
    63 Audi A3 1.4 TFSI Sport
    Gone: 10MY Freelander 2 TD4 HSE Auto, Stornaway Grey. 55 SEAT Alhambra SX 130TDi (Grandad's taxi/shed) Freelander 2 TD4 SE manual, Rimini Red. 07 Passat Est SE 2.0 TDI 140 DSG Blue Graphite
  8. Re: juddering ,loss of power
    Mar 2010
    stafford
    Quote Originally Posted by dunkley201 View Post
    well between the old bolts and new bolts was between 8 to 10 mm difference ,no wonder they was not holding the injectors tight ,replaced bolts at about £2 .50 each ,and worked a treat
  9. Re: juddering ,loss of power
    Apr 2007
    France
    12 Post(s)
    Quote Originally Posted by ghostrider1234 View Post
    8 to 10 mm! How long were the bolts originally? Stretching like that is hard to believe - or were the original bolts too long to begin with?
    2006 (Dec.) B6 2.0TDi 140 Confort | Moka anthracite nacrι | CControl | Highline MFD | Chrome Grill | Meta Targa rear parking sensors | Debadged
    1996 Laguna 2.2D
    1977 MGB roadster
  10. Re: juddering ,loss of power
    Norfolk
    Quote Originally Posted by Quatrelle View Post
    Perhaps the numbers got lost in translation. Stretch bolts stretch in the region of tenths of a millimetre
  1. Bentley announces detailed specification of new mulsanne
    Last Post: 02-03-2010, 08:11 PM
  2. Bentley announces detailed specification of new mulsanne
  3. The efficiency standard – the audi a8 hybrid
    Last Post: 02-03-2010, 07:58 PM
  4. The efficiency standard – the audi a8 hybrid
  5. How does the Quattro system work?
