Thread: Where is the Wiper Relay Located
  1. Where is the Wiper Relay Located
    Mar 2010
    Oxford UK
    Can somebody please point me in the direction of the Wiper Relay on a 2004 T5 combi. My wipers just stopped for no reason, checked fuses and no problem there so want to find the relay??
  2. Re: Where is the Wiper Relay Located
    133 Post(s)
    1986 Post(s)
    There is no wiper relay as such, the wipers are controlled by the “onboard supply control unit” so the first step is a fault code read. Whilst in the diagnostics for the control unit (controller 9 Central electrics) not only can fault codes be viewed but also the wiper motor operated in “outputs tests 03” and the inputs from the switch checked in “measuring blocks 08”. When you say you have checked the fuse, do you mean fuse 10 under the dash? This is the fuse for the switch only, the motor itself is not independently fused.
  3. Re: Where is the Wiper Relay Located
    Nov 2008
    Cramlington,Northumberland
    20 Post(s)
    Have known the Motors to fail on these models.Easy enough to replace.
    Alan.
    VW T6 150 DSG Camper £££
  1. Intermittent stalling - cured - fuel pump relay
    By well oiled in forum Polo - Derby - Lupo - Fox
    Last Post: 16-02-2010, 04:11 PM
  2. Wiper relay
    By BG101045 in forum TT - 8N Forum - 1998 - 2006
    Last Post: 24-11-2009, 08:54 PM
  3. "How To" The FAQ & How To Thread
    By Ben in forum General
  4. Intermittent Wiper Relay - HELP!
    By Steve P in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 21-06-2007, 01:00 PM
  5. wiper relay
    By alanled in forum Touran - Sharan - Caravelle
    Last Post: 22-01-2007, 11:21 PM
