Thread: VCDS - General Question
  1. VCDS - General Question
    Jan 2009
    Sorry for what may be a stupid question.
    Today is my forst day "plying" with VCDS. What is the difference between "adaptation" and "coding"? It appears to me that some values are altered through adaptation ans ome through coding, so why the difference?
  2. Re: VCDS - General Question
    Ambler, PA, USA
    I'll take a stab at this but will preface my reply with the fact that the lines between Basic Settings, Adaptation and Coding seem to blur for many - including me!
    Basic settings are supposed to set the initial basic values needed by a control module.
    Adaptations are parameters that are allowed to change but in a sense fine tune the operation.
    Coding sets the options available within a module.
    Having those ideas in place, we then begin the process of scratching our heads when we look at why certain things are accomplished by adaptation rather than basic settings rather than coding. And you are not alone in being perplexed by the confusion. I have yet to find a document that will help me understand what the engineers were thinking when these three methods were created!
  3. Re: VCDS - General Question
    May 2007
    knee deep in clunge
    14 Post(s)
    basic setting
    Adjustments required for voltage disruptions or replacements of motors
    which require a voltage position feedback
    example
    Throttle position
    wide open throttle partial throttle and closed require voltage steps for continues reference and bi directional information
    Adaption is a setting or request for differing functions of a control unit
    Example
    Convenience bus allows multi network data transfer
    Example
    The radio station can be displayed on the dash display by adapting the the dash to receive the information over can as the message for the radio information makes up a section of the can bus data transfer
    Coding
    Specific to control unit functions and installations
    So the engine ecu needs to be told if the vehicle has a manual or automatic control unit so data can be exchanged for kick down, engine rpm etc over the drive train can
    Hope that helps but its basically code to fitting list, adapt to control functions and basic setting for reference values
    vag diagnostics, retrofits and general repairs
  4. Re: VCDS - General Question
    Jan 2009
    A little clearer thanks but far from intuitive
    Amazed at what you can achieve though. I'll keep tinkering (carefully)
    Ian
  1. General Question about oil
    By elvismiggell in forum Chat - Anything with wheels
    Last Post: 19-11-2009, 10:24 PM
  2. Question Mk3 golf tow bar electrics general question
    By robert1z in forum Golf MK3 - 1993 - 1999
    Last Post: 27-10-2009, 07:31 PM
  3. A reasonable question, I thought......
    By johnvw in forum VCDS - General Questions
    Last Post: 16-06-2009, 07:34 AM
  4. 1.8T S-line general service question.
    By rhencullen1989 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 05-05-2009, 11:02 PM
  5. General question about digi switch over
    By paul b in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 05-12-2007, 01:23 PM
