Thread: 2002 A3 1.9 tdi (130ps) overboost & limpmode - suggestions ?
Results 1 to 10 of 13
  1. 2002 A3 1.9 tdi (130ps) overboost & limpmode - suggestions ?
    I have summarized the fault code identified by VAG com:
    17965/P1557/005463 - Charge Pressure Control: Positive Deviation
    The car occasionally goes into limp mode - usually after some hammering, but not at the exact moment the engine is being gunned. Turbo behaves normally after ignition reset.
    The diagnostics I have undertaken are listed below which will hopefully help you to help me narrow the problem down!
    1. Checked hoses and correct hose configuration with no apparent leaks.
    2. Visually inspected and confirmed turbo waste-gate/actuator rod is traveling freely as intended.
    3. Tested charge pressure using VAG COM, test start/finish in 4th gear from 2000rpm to red line with no significant deviation from spec'd turbo pressure.
    Any suggestions? Could it be a Sticking turbo vein (but is this still possible if actuator rod is moving?) or could it be N75 but guessing this not possible if actuator movement is correct as point 2.?
  2. Re: 2002 A3 1.9 tdi (130ps) overboost & limpmode - suggestions ?
    Oct 2009
    Ashford Kent s,e England
    10 Post(s)
    Yep sticking turbo vanes and yes it is still possible if the actuator rod is still moving, remember that it all resets when ignition is switched off and then restarted,this is a common situation that you are describing and usually requires another turbo,just google overboost/limp mode etc
    Good luck
    Stuart
  3. Re: 2002 A3 1.9 tdi (130ps) overboost & limpmode - suggestions ?
    132 Post(s)
    1980 Post(s)
    In the vast majority of cases 17965 is a carbon fouled turbo which will need to come off and be stripped down for a clean or full rebuild. Vet occasionally 17965 can be the Air Mass Meter (MAF), N75 valve or faulty Thrust (MAP) sensor. In a few cases I have seen the turbo actuating unit stick and this is why I prefer a full rebuild as most rebuilders fit a new capsule.
  4. Re: 2002 A3 1.9 tdi (130ps) overboost & limpmode - suggestions ?
    I just tested the resistance on N75 which was 15ohms but i suppose that should already be ruled out given ive seen the actuator rod move with full travel..
    So, having read around, I strongly suspect the turbo etc needs de-coking because the car has never really been driven hard..
    Limp mode is being triggered not during hard acceleration or even at the red line (when testing) but only after throttle pedal lift off. The only way i can explain this would be to surmise that sticking vanes on lift off will cause the turbo to overrun and create a deviation between spec'd and actual boost as the RPMs fall, ie the engine decelerates much faster but the correct proportion of boost at the RPMs (as they fall) is far higher given the sticking vanes, thus tripping the limp mode ?
    Could that be why i see correct actual and spec'd boost levels testing under load between 2-4000rpms in 4th ?? But the over-boost is happening on the lift of stage?
  5. Re: 2002 A3 1.9 tdi (130ps) overboost & limpmode - suggestions ?
    Norfolk
    " ie as the engine decelerates the turbo is still boosting at a far higher engine RPM due to the sticking vanes.. ?"
    That is exactly what it does because the vanes stick at the maximum boost position which is fine for maximum boost. As soon as you lift off the vanes should change angle for a lower boost but don't 'cos they are stuck.
  6. Re: 2002 A3 1.9 tdi (130ps) overboost & limpmode - suggestions ?
    Thanks so that is why i am not experiencing the problem going hard through the gears ?
  7. Re: 2002 A3 1.9 tdi (130ps) overboost & limpmode - suggestions ?
    Furthermore, assuming its just the vanes sticking slightly, what physical damage can that do apart from being an inconvenience through triggering the limp mode which can be reset with the turn of the key?
  8. Re: 2002 A3 1.9 tdi (130ps) overboost & limpmode - suggestions ?
    132 Post(s)
    1980 Post(s)
    It will get worse and worse until it is undriveable, in a few cases I have seen the turbo overspeed to such an extent they literally explode which makes repairs much more difficult and costly.
  9. Re: 2002 A3 1.9 tdi (130ps) overboost & limpmode - suggestions ?
    Ok but mine does not overboost/speed at the redline and go into limpmode, its only after i lift off the throttle so surely that means its only over spooling on deceleration (relative spec'd boost to the the rpms being out hence goes limp), in which case not actually outside of the limitations of the turbo.. ?
  10. Re: 2002 A3 1.9 tdi (130ps) overboost & limpmode - suggestions ?
    132 Post(s)
    1980 Post(s)
    I had one blow on me in the car park on the overrun after I revved it up at a standstill, it filled the entire charge air system and exhaust with shrapnel and oil. It made a mess on my floor when I pulled the lower intercooler hose off. On one PD I did the exploding turbo damaged a piston.
  1. Trim Confusion
    By ocelot0411 in forum Golf MK5 - 2004 - 2009
    Last Post: 15-08-2009, 11:16 AM
  2. World Debut For The All New Audi A3 Cabriolet
  3. Change from 5sp to 6sp
    By lowndsy in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 27-11-2007, 08:14 PM
  4. Audi A3 TDI 1.9 or 2.0 Buying Advice
    By Danielis in forum Audi A3 - Archive Topics
    Last Post: 18-02-2007, 06:30 PM
  5. Replies: 0
    Last Post: 20-07-2006, 09:08 PM
