Thread: Handbrake button not working
  1. Handbrake button not working
    Oct 2009
    Manchester, England
    Hi all,
    This morning when I came to a set of lights on an incline I pressed the HB button as usual. This time however, the warning "ding" chimed, the button failed to illuminate and engage, and a warning light came up on the dash.
    Is this a common fault and is it easy to fix? ie just a new button or could it prove quite costly?
    Furthermore the car was only in one week ago for the cambelt and oil service...
    Thanks for any help.
  2. Re: Handbrake button not working
    Mar 2009
    York
    could be one of many things and there are many threads here that have covered it. Firstly you can try disconnecting the battery for 5 mins - that sometimes clears the fault and some people have had it never return. A low cost solution is also to try and replace the switch - how old is your model by the way? VW may want to do a software update if necessary - or if its just the switch it would be around £23.
    Every now and then I used to get moments when the brake would fail to come on - the warning light would ding, the message would say 'PB failure', but then completely disappear (as if the computer was a bit confused). Since I fitted a new switch last weekend I've had no problems, plus the button feels far more tactile than my first gen (2005) switch did.
    Hope that helps.
    PS: I forgot to ask - do you still have the warning light on?
    A3 8V S-Line Cabriolet 2.0 TDI
    Passat B6 FSI • Passat TDI 105 • BMW E90 318d • BMW F30 320d Lux
  3. Re: Handbrake button not working
    Apr 2007
    France
    12 Post(s)
    1996 Laguna 2.2D
    1977 MGB roadster
  4. Re: Handbrake button not working
    Oct 2009
    Manchester, England
    Thanks for the help guys, I had a read of the other thread too - very useful.
    Mine is on a 55 plate with 74K on the clock now. I found when I drove home last night the switch worked once but then failed again. This morning was exactly the same and the dash warning symbol is still on.
    I'll buy a new switch and see if that rectifies the problem.
    Thanks again,
    Fletch
  1. Please Help Mode button not working. Cannot reset time!
    By vipergrm in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 17-05-2010, 10:07 PM
  2. Ever wondered what happens when you push the handbrake button whilst driving ?
    By carl s in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 16-03-2010, 07:39 PM
  3. Handbrake button vibration
    By campaxton in forum Audi A3 - Archive Topics
    Last Post: 18-12-2007, 01:21 PM
  4. 2 button and 3 button fobs / remotes
    By Loofer in forum Archive posts
    Last Post: 07-08-2007, 02:08 PM
  5. Passat Electronic Handbrake Problems
    By wildinthecountry in forum Passat - Archive Topics
    Last Post: 08-10-2006, 05:39 PM
