Thread: Help on polishing inlet manifold vr6
  1. Help on polishing inlet manifold vr6
    Mar 2009
    I have a 97 golf vr6 wanting to know if any easy way to polish it up but leave it on the car as i dont really have tools to remove
    i have been on it for a couple of hours with rough sand paper and fine wet and dry and using autsol but its taking forever also hard to get into the grooves
    any help welcome cheers
  2. Re: Help on polishing inlet manifold vr6
    Pembrokeshire
    22 Post(s)
    i use a sealey multi tool, rather like a dremel for jobs like this. you need plenty of sanding rolls for it, and about a week off. its a long job to do properly, and half a job look worse than nothing. only when you have polished up a manifold do you appreciate why companies charge so much to do it. basically get a flat finish with the dremel, then carry on by hand with the wet n dry, until it shines. some clear engine laquer will keep it shining for longer.
    for larger surfaces where you can get access, i use a da sander.
  3. Re: Help on polishing inlet manifold vr6
    Mar 2009
    well here it is not quite finished, goin to mask off all hard work and spray between grooves etc withgloss black engine paint, but all done started with rough paper and worked upto 1200 wet and dry grit paper arm is killing me! but happy with end result just got to do the sraying and clean up engine bay now lol
  1. EGR and Inlet Manifold Cleaned
    By MagicMat in forum Golf MK4 - 1999 - 2004
    Last Post: 21-07-2010, 12:02 AM
  2. Please Help Noise from inlet manifold?
    By Pdlk24 in forum A8 - S8 - V8
    Last Post: 25-01-2010, 10:25 PM
  3. Renewing inlet manifold on mk4 golf tdi
    By chrissboro in forum Golf MK4 - 1999 - 2004
    Last Post: 25-09-2009, 07:07 PM
  4. Oil on inlet manifold mk4 gt tdi 110
    By veedub76 in forum Golf MK4 - 1999 - 2004
    Last Post: 12-04-2008, 06:57 PM
  5. 1.8 8v inlet manifold getting hot
    By oli325 in forum Golf MK1 - 1974 -1984
    Last Post: 28-03-2008, 07:37 PM
